maikan
Everything posted by maikan
Mid Skid Plate Project Is ...*FINISHED*
maikan replied to fleurys's topic in 96-2004 R50 Pathfinders
Is there a heat build up between the plates and the mechanical part. Because on the site of rasta 4x4 theytalk about air intake to help prevent damage. Can that be an issue or is it salesperson talk Rasta 4X4 Pathfinder page -
If I want lock the bolts with permatex, do I need to have high temp or regular is fine.
I have already slept in my path and I find it a little bit short. But with the deck that go over the folded rear seat it look great. Can you tell me what lengh it gives you. And a teardrop trailer is great too ! Wher did you take your plan, was this a costly project.
Why would you say that stock VG33 is a bad platform and is hold by crap around it ?? What is holding it back ?
It is a stud that failed, one of the stud kit that came with the hubs If I find high grade replacement stud I will upgrade. When you say that you bought high grade bolts, you mean that you didn't use studs, you use bolts instead ?
There was a kind of retaining ring on the shaft that I took off to get the old hub out. Do I nedd to put it back on the shaft after the install of warn hubs ? ( Wasn't sure but I did )
Have an other question: When my hub was off I notice a play in the shaft. It was a good at least a 1/8 to 1/4 from side to side. The grease was looking very dark too. Is there something abnormal here. Thanks
I was installing my manual hubs today and when I was tightening the bolts that link hubs with wheels my stud broke at maybe 15 pounds of force !! Luckily I was able to unscrew the stud with a plier. Two questions for you : 1- Where can I find new stud ? From what I saw Warn don't sell them 2- How can I screw the stud ?? Do I need to screw the studs very tight or this don't matter ? And after screwing the studs I notice that they are not the same lenght. And for now I drive with a Warn hub on one side and the stock on the otherside. If I keep it locked is there a problem?
I live in an area where I canlive without AC My belt is going away and I am low on freon. Can I trash the AC without any complication ??
Jte dis qu'ton translater marchrait pas pantoute pis qu'tu comprendrais arien de cque jdis. But for the sake of all, english is the dedicated language in here. (I said that google translater only work with textbook grammar not well with local language)
Whooo This a little gore for a car commercial. In canada they would have all the pet lovers crying for banning this. But this is original, I can give them that I talk about the little evin twin or course.
Hi everyone I tried to seach on this but I don't quite handle it. So last weekend was spent on the trails, but we took longer than we taugh and darhness surrounded us. Eventually I had to bach up, but my pathfinder didn't came with factory back up lights. S o I decided to intall some. I bought some utility lights and wired them to the backing light in the taillight. But some people frighten me about how unsafe it is and I think I don't have a lot of juice because Lights seem weak. So is there anybody who know about a how-to threads on wiring off-road lights with fuse and switches and etc... Thanks
Thank you for the link, It seems very complex, but I will see. For those who done it or hear about, do you notice a vey big improvement.
De plus en plus de Quebecois! Welcome to the board, I will try to keep my ointervention in english, I don' t want everybody thinking that we are trash talking them. I am sure you will find all the info you are looking for, because I do. Maybe we will see us on the trails.
Un autre membre de Quebec ! It is great to see another NPORA member from Quebec. Welcome
This a great upgrade to our R50 This front lokka is a project a hope to tackle in a near future. And for the rear diff, it would be great if someone do a thread on that. I didn't know we could add strengh to our rear LSD
Wow great for you to pass the test ! Good for me we don't have emission test here, cause I don't understand how you pass. But you are sitting on 33x10.5 and have almost no rubbing ? I have a 99 and rub a little on 31, just can't imagine 33 ! I should take a look at my suspension and look into a lift
I have 31x10.5 R15 and they are sbout the same size as 265x70 R16 My truck is 99 and the tire are rubbing a LITTLE when I back up at full lock If you can live with that, go ahead it is very minor. But I think I have wheel with more backspacing than stock, I don't know for sure and I don't know how to mesure
Re-Filling The Transfercase...without Making A Huge Mess?
maikan replied to kcpath's topic in The Garage
This thing is so geniously nice !! For ten bucks it is the way to go. Far more practical than my suction grease gun.link Should have looked better before buying that gun -
If you only want to tow seadoos Just get newer parts. We tow all the times two ATV or Ski-doo. We blow the tranny towing wood. But the suspension always was up to the task
Nice truck ! Is it for sale ?
I can't have access to the PDF How-To. Is this a problem with my computer or this document is lost in the immensity of the web. Have these code (knock sensor, O2) and I want to get rid of these.
Yeah, same thing for me. Have them for like many years. There is a thread who talk about harness replacement and fixing these kind of code My link
Yeah your right, I spent over 600 for tires maybe will spend a thousand for a lift So i will not play it greedy and change the whole thing. Don't want to be like the Quebec government, building a bridge with the cheapest material possible.
So at the oil change I just check if the fluid is dirty and if it is (having metal shaving in it ) I do a oil filter change too ??
