Power Lock Issues
I have the dreaded power lock failure. It started with random lock and unlock. Then they would quit for days at a time, then weeks at a time, and now they are dead. They wont work with the master switch or the keyless entry. The keyless entry/alarm system started acting up at the same time. Sometimes the alarm would set without locking the doors, sometimes the alarm wouldn't set but the doors would lock. Other times the alarm would deactivate, but the doors wouldn't unlock. Then I would hit a big pothole and everything would be perfect for a while. I searched the boards for sucessful fixes for this problem but didn't find anything helpfull. My brother has the exact same problem in his '95 Pathy as well. I have started disassembling the interior in search of the problem. At this point, I have checked all the connectors in the drivers door (electrical and mechanical), removed the master switch from the door and disassembled it, and removed the actuator and tested it with a direct connection to the battery. Everything seems good. I tested the voltage at the wires that plug into the actuator and it was very low(about 8 volts), oddly - there were two volts in these wires without even touching the master switch. Does anyone here know where the relay for the power locks is located? How do you get to the factory alarm to troubleshoot it? Any suggestions where to look next? It would be nice to solve this common problem once and for all. I have a bad feeling that it is in the factory alarm or computer though but I will try my best to fix this. Any help would be greatly appreciated.
Edited by captainsae
Well, if at least one of us can fix theirs we can start making a list of things to look for. I'm leaning towards a faulty alarm/keyless entry system. I wonder if there is an easy way to bypass the alarm to test the rest of the system. The dealer was no help either - they just said they would have to keep replacing part$$ until they could get it to work.
Thanks for the advise! Where is the timer and the relay located? I checked the main switch and it looked good. I dont believe I have any other door lock switches on the other doors.
I had a similar problem in my 95, and found that there's a breaker in the driver's side kick panel that is for the locks......I could not get my truck to lock/unlock with the door switch or my alarm system's remote. I found this breaker, which was corroded, cut it out, wired in a fuse, and it's worked flawlessly ever since.
I vote for relay timer or the little plastic piece tied to the lock.
Push the button when its quiet you should hear a ticking coming from the rear driver side cargo area. That's where the timer relay is located if it's ticking it's still working.
Simon - I looked under the kick panel and didn't find a breaker or a fuse block. Just a bunch of what looks like relays. I didn't see any signs of corrosion.
Gotrek- Do you know which one of the boxes is the timer? There are several. I do not hear ticking.
yea I am having the same problem with the remote not unlocking the doors. I as well have no corrosion under the kick panel, I do have 3 relays, it kinda looks like its missing one but theres only one contact for it. Are we supposed to have 4? But yea as captain said above which of the relays in the back is it? There are 4 grouped together up there among other wires and connectors.
Good news! The problem IS the lock timer! So give Cuong and Gotrek a prize. Unfortunately, all my solder joints were good so I guess I need to replace it with a new one. To get to the timer, you have to remove the interior panels on the driver's side of the cargo area. Start by unscrewing the pins that hold the trim strip under the hatch, then you can pull that up. The side panel snaps into place so just give it a good tug starting on one side and work your way across until it is off. You will see a grey box mounted with a ground wire for something attached to the mounting bolt. It says lock timer right on the box. As soon as I started pulling it out, my locks activated for the first time in months. I took it apart by using a very small screwdriver to pry one end out and the circuit board just slid out. I checked all the solder connections and they looked perfect so I put it all back together. At first the locks didn't work but I jiggled the plugs a little and now they are working perfect. So I guess the next time I hit a bump they will act up again. I'll try to pick up a new timer tomorrow if I can. I'll let you know if jiggling the wires does anything with the new timer.
Just wanted to give an update on the lock timer. The new one came in today and I installed it. Everything works perfect now. Even when I jiggle the wires everything works perfect. So, I think we have found the problem for the very common power lock failure that nobody else in the world (except for us) seems to know anything about.
  • 6 months later...
  • 3 weeks later...
