Guest SuperSon Posted March 4, 2007 Share Posted March 4, 2007 (edited) hey guys i just got an email from TC and was notified that the BL that I ordered is on back order. I was told that the 86-90 HB BL would work on the 93 just needs a different bolt for the back. Would the 86-90 Pathy BL work on the 93? Im trying not to order it from AC and found some on ebay that I was hoping would work coz its $50 cheaper PERFORMANCE ACCESORIES BODY LIFT Edited March 4, 2007 by SuperSon Link to comment Share on other sites More sharing options...
LD50 Posted March 4, 2007 Share Posted March 4, 2007 You'll spend $20 on the bolts anyways, if you can even find the right ones. Link to comment Share on other sites More sharing options...
Guest SuperSon Posted March 4, 2007 Share Posted March 4, 2007 Pavelow is going to send me some Link to comment Share on other sites More sharing options...
LD50 Posted March 4, 2007 Share Posted March 4, 2007 It should work just fine then Link to comment Share on other sites More sharing options...
Guest SuperSon Posted March 4, 2007 Share Posted March 4, 2007 not really sure after doing some cross referencing. PN# is 4052 and 4053. Im assuming the last number is the amount of lift desired or the thickness of the lift blocks Link to comment Share on other sites More sharing options...
LD50 Posted March 4, 2007 Share Posted March 4, 2007 (edited) I'm pretty sure the only thing AC does is add the correct bolts, the kits are otherwise the same between the 2 pathfinder kits Edited March 4, 2007 by LD50 Link to comment Share on other sites More sharing options...
RedPath88 Posted March 4, 2007 Share Posted March 4, 2007 Yes the last digit signifies the amount of lift Link to comment Share on other sites More sharing options...
Guest SuperSon Posted March 5, 2007 Share Posted March 5, 2007 Thanks guys. Ill buy the one on ebay Link to comment Share on other sites More sharing options...
GrimGreg Posted March 5, 2007 Share Posted March 5, 2007 Hope the E-Bay seller is just using a generic pic, because the lift in the pic isn't for a Pathy, FYI. Link to comment Share on other sites More sharing options...
Guest SuperSon Posted March 5, 2007 Share Posted March 5, 2007 I sent him an email to make sure and mentioned to him that the pic is not the actual kit for that specified year.The part number is the right one tho. Ill call tomorrow morning to verify before I make this purchase Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 5, 2007 Share Posted March 5, 2007 The HB kits contain an extra 4 body blocks for the bed. HB's have more mounting points between the frame and body/bed. I think that's the only difference. My kit was for EITHER an HB or a Pathy and I ended up with 4 blocks left over. Link to comment Share on other sites More sharing options...
