Poppasmurf Posted September 14, 2020 Share Posted September 14, 2020 New to the forum, probably joined the wrong forum- but there is so much expertise here. I'm an old fart and enjoy twisting wrenches. I am in the process of buying either a std trans Xterra or Pathie. I want something to tow behind our new to us motor home. I've found a pretty good body and package of 2001 Xterra with a holed engine. Question to resident experts- am I limited (practically speaking) to replacing with another 3.3, or can one dream bigger with a 3.5 (with attending ECM and wiring problems). I don't want to hot rod the thing, just good torque and able to pull my small 16' fiberglass boat. From what I've read and understand, a standard transmission is the only way I can tow either of the mentioned vehicles. Any input would be welcome. Thanks. Link to comment Share on other sites More sharing options...
Precise1 Posted September 16, 2020 Share Posted September 16, 2020 Welcome Poppa, and yes, the hive mind here knows damn near everything about Pathfinders and related motors/vehicles. IIRC the 3.3 is your only reasonable option. The VQ35 is a totally different animal needing a different mounting/transmission/rear end... I don't know that anyone has done it, but I don't know everything either. There are a few things you can do the to 3.3 to wake it up some though. Run something other than the stock intake/air box, port/polish the intake/plenum, install stage 1 cams or cams from a VG30, but I don't know about down stream exhaust mods/gains downstream of the two cats/O2 sensors. Then there is the supercharged version of the VG33 out of a Frontier or Xterra, but those are pricey and in high demand. Anyway, look around and do some searches, the info is here... B Link to comment Share on other sites More sharing options...
Slartibartfast Posted September 17, 2020 Share Posted September 17, 2020 My dad had a 3.3 Xterra (non-supercharged, autotragic) and it struggled to tow a small camper trailer. 3.0 cams probably would've helped. If you want the 3.5, probably better to look for an R50, though manual 3.5 R50s aren't exactly common. Link to comment Share on other sites More sharing options...
RainGoat Posted September 17, 2020 Share Posted September 17, 2020 A 3.5 R50 will have no problem towing. With the 3.5 you don’t need the manual, though they can be fun. The VAST majority are auto though. Link to comment Share on other sites More sharing options...
