FUELER
how to pull SES code using screw on PCM?
EDIT:
cool guy on 4x4parts.com told me:
" the easiest way to do it is to get the haynes manual from an auto parts store, it has step by step instructions.
The quick and dirty is , pull the computer out, turn the ignition on but do not start the engine. then you turn the screw in the computer through the hole all the way (forget Which way) wait for 2 seconds, then turn it back...then you get flashie codes."
I have found autozones free OBD2 scanner ($60 value) to be even easier
Edited by FUELER
OBD II Codes
With Consult
  1. Turn ignition Off.
  2. Connect ‘‘Consult’’ the data link connector (DLC), located behind fuse box cover.
  3. Turn ignition On.
  4. Touch ‘‘Start.’’
  5. Touch ‘‘Engine.’’
  6. Perform each diagnostic test mode according to each service procedure.
Without Consult
  1. Turn ignition On.
  2. Turn diagnostic mode selector on ECU fully clockwise and wait until inspection lamps flash. Number of flashes displayed indicates corresponding mode.
  3. Note number of flashes, then immediately turn diagnostic mode selector fully counterclockwise.
  4. If ignition is turned Off during diagnosis, in each mode, and then turned back on again after power to the ECU has dropped off completely, diagnosis will automatically return to Mode I.
  5. For description of modes, proceed as follows:
        1. (Mode I): with engine stopped, system in bulb check state. with engine running, system in malfunction warning state.
        2. (Mode II): with engine stopped, system in self diagnostic results state. with engine running, system in front O2S monitor state.
Clearing Codes
If using a scan tool, follow tool manufacturer’s instructions to clear Codes.
Using a small screwdriver to turn the diagnostic mode selector switch, located on the side of the ECM/ECU, fully clockwise. After waiting two seconds, rotate the switch to the full counterclockwise position. The diagnosis will end and memory will then be cleared.
Disconnect the car battery for at least 24 hours.
Code Number  Component  Bulletins Available for Models.....
P0000  No Self Diagnostic Failure Indicated
P0011  Intake Valve Timing Control
P0021  Intake Valve Timing Control
P0031  O2 Sensor Heather
P0032  O2 Sensor Heather
P0037  O2 Sensor Heather
P0038  O2 Sensor Heather
P0043  O2 Sensor Heather
P0044  O2 Sensor Heather
P0051  O2 Sensor Heather
P0052  O2 Sensor Heather
P0057  O2 Sensor Heather
P0058  O2 Sensor Heather
P0100  MAF (Mass Air Flow) Sensor
P0101  MAF Sensor
P0102  MAF Sensor
P0103  MAF Sensor
P0105  Absolute Pressure Sensor
P0107  Absolute Pressure Sensor
P0108  Absolute Pressure Sensor
P0110  IAT (Intake Air Temperature) Sensor
P0112  IAT  Sensor
P0113  IAT  Sensor
P0115  ECT (Engine Coolant Temperature) Sensor
P0117  ECT Sensor
P0118  ECT Sensor
P0120  TP (Throttle Position) Sensor
P0121  TP Sensor
P0122  TP Sensor
P0123  TP Sensor
P0125  ECT Sensor
P0127  Intake Air Temperature Sensor
P0128  Thermostat Function
P0130  Closed Loop, Bank 1 Or Front O2S, Bank 1
P0131  Front O2 Sensor, Bank 1 Lean Shift Monitoring
P0132  Front O2 Sensor, Bank 1 Rich Shift Monitoring
P0133  Front O2 Sensor, Bank 1 Response Monitoring
P0134  Front O2 Sensor, Bank 1 High Voltage
P0135  Front HO2S Heater, Bank 1
P0136  Rear O2S, Bank 1
P0137  Rear O2S, Bank 1 Minimum Voltage Monitoring
P0138  Rear O2S, Bank 1 Maximum Voltage Monitoring
P0139  Rear O2S, Bank 1 Response Monitoring
P0140  Rear O2S, Bank 1 High Voltage
P0141  Rear H02S Heater, Bank 1
P0144  O2 Sensor Heather
P0150  Closed Loop, Bank 2 Or Front O2S, Bank 2
P0151  Front O2 Sensor, Bank 2 Lean Shift Monitoring
P0152  Front O2 Sensor, Bank 2 Rich Shift Monitoring
P0153  Front O2 Sensor, Bank 2 Response Monitoring
P0154  Front O2 Sensor, Bank 2 High Voltage
P0155  Front HO2S Heater, Bank 2
P0156  Rear H02S Sensor, LH Bank
P0157  Rear O2S, Bank 2
P0158  Rear O2S, Bank 2
P0159  Rear O2S, Bank 2
P0160  Rear O2S, Bank 2
P0161  Rear H02S Heater, LH Bank Or Bank 2
P0171  Fuel System Lean, Bank 1
P0172  Fuel System Rich, Bank 1
P0174  Fuel System Lean, Bank 2
P0175  Fuel System Rich, Bank 2
P0180  Tank Fuel Temp Sensor
P0182  Fuel Tank Temperature Sensor
P0183  Fuel Tank Temperature Sensor
P0217  Engine Coolant High Temperature Enrichment Protection
P0221  Throttle Position Sensor
P0222  Throttle Position Sensor
P0223  Throttle Position Sensor
P0226  Accelerator Pedal Position Sensor
P0227  Accelerator Pedal Position Sensor
P0228  Accelerator Pedal Position Sensor
P0245  Supercharger Bypass Valve Control Solenoid Valve
P0300  Random Misfire
P0301–P0308  Misfire, Cylinder No. 1–8
P0325  Knock Sensor, Bank 1
P0327  Knock Sensor
P0328  Knock Sensor
P0330  Knock Sensor, Bank 2
P0335  CKP (Crank Shaft Position) Sensor
P0340  CMP (Cam Shaft Position) Sensor (Phase)
P0345  CMP Sensor (Phase)
P0350  Ignition Signal
P0400  EGR System
P0402  EGRC/BPT Valve
P0403  EGR Volume Control Valve Circuit
P0405  EGR Temperature Sensor
P0406  EGR Temperature Sensor
P0420  TW (Two-Way) Catalyst System, Bank 1  Altima
P0430  TW Catalyst System, Bank 2
P0440  EVAP Small Leak
P0441  EVAP Control System Purge Flow Monitor
P0442  EVAP Control System  Z, Quest, Murano, Maxima
P0443  Purge Control/V & S/V
P0444  EVAP Canister Purge Volume Control Solenoid Valve
P0445  EVAP Canister Purge Volume Control Solenoid Valve
P0447  EVAP Canister Vent Control Valve
P0450  EVAP Pressure Sensor
P0451  EVAP System Pressure Sensor
P0452  EVAP System Pressure Sensor
P0453  EVAP System Pressure Sensor
P0455  EVAP Control System
P0456  EVAP Control System  Z, Quest, Murano, Maxima
P0460  Fuel Level Sensor Unit (Slow)
P0461  Fuel Level Sensor Function
P0462  Fuel Level Sensor
P0463  Fuel Level Sensor
P0464  Fuel Level Sensor Circuit
P0500  Vehicle Speed Sensor
P0505  IACV/AAC Valve
P0506  Idle Speed Control System
P0507  Idle Speed Control System  Most Nissan Models
P0510  Closed TP Sensor
P0550  Power Steering Pressure Sensor
P0600  A/T Comm Line
P0605  ECM/ECU
P0650  Malfunction Indicator Lamp
P0705  PNP Or Inhibitor Switch
P0710  ATF Temp Sensor
P0720  VSS A/T
P0725  Engine Speed Signal
P0731  A/T 1ST Signal
P0732  A/T 2ND Signal
P0733  A/T 3RD Signal
P0734  A/T 4TH Signal Or TCC
P0740  TCC SV Solenoid
P0744  A/T TCC Signal
P0745  Line Pressure S/V
P0750  Shift Solenoid/V A
P0755  Shift Solenoid/V B
P1031  Air/Fuel Ratio Sensor Meter
P1032  Air/Fuel Ratio Sensor Meter
P1065  ECM Power Supply Heater
P1102  Mass Air Flow Sensor Function Heater
P1103  MAP Sensor Heater
P1104  MAP Sensor Heater
P1105  MAP/BARO Switch SOL/V
P1108  MAP Sensor Heater
P1110  Intake Valve Timing Control, LH Bank
P1111  Intake Valve Timing Control Solenoid Valve
P1119  Radiator Temperature Sensor Circuit
P1120  TP Sensor 2
P1121  Electronic Throttle Control Actuator
P1122  Electronic Throttle Control Actuator
P1124  Throttle Control Motor Relay
P1125  Tandem TP Sensor
P1126  Throttle Control Motor Relay
P1128  Throttle Control Motor
P1130  Swirl Control Valve Control Solenoid Valve
P1131  Swirl Control Solenoid Valve
P1132  Swirl Control Valve
P1135  Intake Valve Timing Control, RH Bank 2
P1136  Intake Valve Timing Control Solenoid Valve
P1137  Swirl Control Valve Position Sensor
P1138  Swirl Control Valve
P1140  Intake Valve Timing Control Position Sensor, LH Bank 1
P1143  Heated O2 Sensor 1
P1144  Heated O2 Sensor 1
P1145  Intake Valve Timing Control Position Sensor, RH Bank 2
P1146  Heated O2 Sensor 2
P1147  Heated O2 Sensor 2
P1148  Closed Loop, Bank 1
P1163  Heated O2 Sensor 1
P1164  Heated O2 Sensor 1
P1165  Swirl Control Valve Control Vacuum Check Switch
P1166  Heated O2 Sensor 2
P1167  Heated O2 Sensor 2
P1168  Closed Loop, Bank 2
P1169  Heated O2 Sensor 3
P1170  Heated O2 Sensor 3
P1210  Traction Control Signal Circuit
P1211  ABS/TCS Control Unit
P1212  ABS/TCS Communication Line
P1217  Engine Coolant Temperature
P1220  FPCM
P1221  Throttle Actuator Circuit
P1222  Temperature Sensor Circuit
P1223  Throttle Position Sensor 2
P1224  Throttle Position Sensor 2
P1225  Closed Throttle Position Learning
P1226  Closed Throttle Position Learning
P1227  Accelerator Pedal Position Sensor 2
P1228  Accelerator Pedal Position Sensor 2
P1229  Sensor Power Supply
P1271  Air/Fuel Ratio Sensor 1
P1272  Air/Fuel Ratio Sensor 1
P1273  Air/Fuel Ratio Sensor 1  Altima, Altima, Quest, Maxima
P1274  Air/Fuel Ratio Sensor 1
P1276  Air/Fuel Ratio Sensor 1
P1278  Air/Fuel Ratio Sensor 1
P1279  Air/Fuel Ratio Sensor 1
P1320  Ignition Signal, Primary
P1335  CKP Sensor (Ref)
P1336  CKP Sensor (POS) Cog
P1400  EGRC Solenoid/V
P1401  EGR Temp Sensor
P1402  EGR System
P1440  EVAP Small Leak  Altima, Frontier, Pathfinder, Quest, Xterra
P1441  VC/V Bypass/V
P1443  Canister Control Vacuum Check Switch
P1444  Purge Volume Control/V  Altima, Frontier, Pathfinder, Quest, Xterra
P1445  Purge Volume Control/V
P1446  Vent Control Valve
P1447  EVAP Purge Flow
P1448  Vent Control Valve
P1456  EVAP Control System
P1464  Fuel Level Sensor Circuit Ground Signal
P1480  Fan Control Solenoid Valve Circuit
P1490  VC/V Bypass/V
P1491  VC Cut/V Bypass/V  Altima, Frontier, Pathfinder, Quest, Xterra
P1492  Purge Control/V S/V
P1493  Purge Control/V & S/V
P1564  ASCD Steering Switch
P1568  ICC (Intelligent Cruise Control)
P1572  ASCD (Automatic Sped Control Device) Brake Switch
P1574  ASCD Vehicle Speed Sensor
P1605  A/T Diag Comm Line
P1610  NATS Malfunction
P1611  NATS Malfunction
P1612  NATS Malfunction
P1613  NATS Malfunction
P1614  NATS Malfunction
P1615  NATS Malfunction
P1705  TP Sensor A/T
P1706  PNP Switch
P1720  Vehicle Speed Sensor- A/T Output
P1760  Overrun Clutch S/V
P1775  Torque Converter Clutch Solenoid Valve
P1776  Torque Converter Clutch Solenoid Valve
P1780  Shift Change Signal
P1800  VIAS Control Solenoid Valve
P1805  Brake switch
P1900  Cooling Fan
P2122  Accelerator Pedal Position Sensor
P2123  Accelerator Pedal Position Sensor
P2127  Accelerator Pedal Position Sensor 2
P2128  Accelerator Pedal Position Sensor 2
P2135  Throttle Position Sensor
P2138  Accelerator Pedal Position Sensor
U1000  CAN* Comm Circuit  Most Nissan Models
U1010  CAN* Comm  Most Nissan Models
*CAN (Control Are Network)
you're welcome. :takebow:
:idea: Ahh!
So there is an 0021 code.
And I thought they all started with 11xx or 12xx
Silly me P...
:idea: Ahh!
Silly me P...
Sorry to dig up an old thread - anybody know what is going on when an R50 throws P0021? All I can find is this page: http://www.engine-light-help.com/P0021-che...gine-light.html
...but it's pretty generic info, so I wondered if anybody had VQ specific experience??
I have always wondered why there where two different codes for the same exact problem.
For instance, code 1132 and 1138 both = swirl control valve?
it does what is says in the link.
1132 1138
because there are many that are duplicate. these codes are the same for all vehicles. they've doubled them to have options in the future.
