rennwerkes Posted July 14, 2006 Share Posted July 14, 2006 Folks, checked my rear hatch pins and the problem one isn't cross threaded. For whatever reason it's moving around in the hatch but is tight enough where it stays put (but not solid) if that makes any sense! Here's my question, I've got new pins with my new shock. Does anyone think that JB weld will be strong enough to hold it put? The old pin actually bent upward enough to allow the old shock to slip off when the gate was closed. Or should I use some other means to angle the pin a bit back? Perhaps half a washer or something like that? The parts guy at Nissan suggested I just weld the damn thing! LOL! TIA! Link to comment Share on other sites More sharing options...
94extreme Posted July 14, 2006 Share Posted July 14, 2006 jb weld would definitely be worth a shot. Link to comment Share on other sites More sharing options...
FLApathy Posted July 14, 2006 Share Posted July 14, 2006 jb weld would definitely be worth a shot. eh, camo duck tape will work too Link to comment Share on other sites More sharing options...
rennwerkes Posted July 14, 2006 Author Share Posted July 14, 2006 Thanks guys! I'll probably do both. Use something to give the pin a bit of an angle to straighten things up and JB Weld it. Should I scrap things down to bare metal before applying the JB Weld? Link to comment Share on other sites More sharing options...
rennwerkes Posted July 17, 2006 Author Share Posted July 17, 2006 Here's my update. I used half a washer and JB weld to level things off. Screwed the new pin in and SO FAR things are holding up. I know there's a huge amount of pressure exerted on that small pin by the hatch shock so I'm still a little skeptical that's it's going to last in the long term but damn, it sure is nice not having to use my mop handle to hold things up! Link to comment Share on other sites More sharing options...
dagwoodzz Posted July 17, 2006 Share Posted July 17, 2006 it sure is nice not having to use my mop handle to hold things up! Ha! I've been using a wire brush since the purchase. Close to 2 yrs now. I must be the cheapest guy on the board! Link to comment Share on other sites More sharing options...
GrimGreg Posted July 17, 2006 Share Posted July 17, 2006 I would use a real weld and re-tap the hole. Link to comment Share on other sites More sharing options...
rennwerkes Posted July 17, 2006 Author Share Posted July 17, 2006 I agree. Will probably do it in the near future. Thanks! Link to comment Share on other sites More sharing options...
