cdhicks99 Posted July 13, 2006 Share Posted July 13, 2006 I have been thinking..what adverse affects could there be from welding the front diff.? I would think as long as it's never locked in on the road there should be no problems. Link to comment Share on other sites More sharing options...
Spolar93 Posted July 13, 2006 Share Posted July 13, 2006 it will be hard to steer offroad with 4hi/lo engaged. also, the front diffs are not that strong to begin with, so welding it up will just add more strain. i've blown my front r&p without welding it. Link to comment Share on other sites More sharing options...
cdhicks99 Posted July 13, 2006 Author Share Posted July 13, 2006 Thanks Spolar, thats what I needed to know. Link to comment Share on other sites More sharing options...
max_stryker Posted July 13, 2006 Share Posted July 13, 2006 yeah i wouldnt weld up the front for safety reasons (steering) Link to comment Share on other sites More sharing options...
FLApathy Posted July 13, 2006 Share Posted July 13, 2006 yeah even if you could steer your CV's and steering and yada yada would make it Link to comment Share on other sites More sharing options...
Spolar93 Posted July 13, 2006 Share Posted July 13, 2006 well, actually, if you had manual hubs, you could always get out and unluck the inside hub when turning. but i would be worried about your cv axles exploding if they got too much traction. especially at full lock. Link to comment Share on other sites More sharing options...
Filthy Luker Posted July 13, 2006 Share Posted July 13, 2006 well, actually, if you had manual hubs, you could always get out and unluck the inside hub when turning. Have you ever seen that on trails? It's frakin' hilarious. Poor bastard was so pissed off at getting out every 30 seconds. Simple answer to fix the steering issue is hydro assist. Link to comment Share on other sites More sharing options...
94extreme Posted July 13, 2006 Share Posted July 13, 2006 Simple answer to fix the steering issue is hydro assist. more torque on already weak steering? Link to comment Share on other sites More sharing options...
FLApathy Posted July 13, 2006 Share Posted July 13, 2006 more torque on already weak steering? i think thats the point Mz Link to comment Share on other sites More sharing options...
Filthy Luker Posted July 13, 2006 Share Posted July 13, 2006 My buddy uses hydro assist with great success on his welded up front end and he's got 37"s.... :Magic: Link to comment Share on other sites More sharing options...
