Guest rayj Posted July 11, 2006 Share Posted July 11, 2006 help my oil light is on oil is full and my mortor is ticking does that mean i need a oil pump Link to comment Share on other sites More sharing options...
Filthy Luker Posted July 11, 2006 Share Posted July 11, 2006 no it means you need a new engine Link to comment Share on other sites More sharing options...
max_stryker Posted July 11, 2006 Share Posted July 11, 2006 no it means you need a new engine yeah motor knocks are bad.... Link to comment Share on other sites More sharing options...
Filthy Luker Posted July 11, 2006 Share Posted July 11, 2006 yeah motor knocks are bad.... don't you mean MORTOR knocks? Link to comment Share on other sites More sharing options...
Guest Muhandes Posted July 11, 2006 Share Posted July 11, 2006 nah he needs a new mortor Link to comment Share on other sites More sharing options...
88pathoffroad Posted July 11, 2006 Share Posted July 11, 2006 The ticking may just be your exhaust, we can't tell from over here. Check the oil pressure sensor and make sure it's plugged in. It's right beside the oil filter, only thing screwed into the engine block next to it. Link to comment Share on other sites More sharing options...
Filthy Luker Posted July 11, 2006 Share Posted July 11, 2006 Check the oil pressure sensor and make sure it's plugged in. It's right beside the oil filter, only thing screwed into the engine block next to it. If the oil pressure sensor wiring is not connected, there is no light. Link to comment Share on other sites More sharing options...
Precise1 Posted July 11, 2006 Share Posted July 11, 2006 no it means you need a new engine No, not necessarily... Your sensor could be bad, you could need an oil pump, it could be wiring... The ticking could be a valve, manifold leak, etc... Don't drive it until you know you have oil pressure and then try to determine where the ticking is comming from. B Link to comment Share on other sites More sharing options...
88pathoffroad Posted July 11, 2006 Share Posted July 11, 2006 If the oil pressure sensor wiring is not connected, there is no light. This is true, but if it were unplugged and grounded out on the exhaust or something, it'd do that. Link to comment Share on other sites More sharing options...
Filthy Luker Posted July 11, 2006 Share Posted July 11, 2006 This is true, but if it were unplugged and grounded out on the exhaust or something, it'd do that. True... Mine comes undone all the time and it flickers like crazy when it touches stuff around. Link to comment Share on other sites More sharing options...
