k9sar Posted September 29, 2006 Share Posted September 29, 2006 Link to comment Share on other sites More sharing options...
88pathoffroad Posted September 30, 2006 Share Posted September 30, 2006 Very nice! Good to know. Link to comment Share on other sites More sharing options...
solid snake Posted October 1, 2006 Author Share Posted October 1, 2006 Sorry to report that the same problem is back, even with the module swap. I trieds to run th diagnostic codes and I don't get any judgement flickers. It's really pissing me off cause I am following the direction just like the pdf file that's pinned in the garage section and nothing. Link to comment Share on other sites More sharing options...
stumo Posted December 1, 2006 Share Posted December 1, 2006 I tried the FSM method quite a while ago and it didn't work with mine either. The wire from the vehicle speed sensor broke at the AT end. When I turned on the ignition, the AT check light flashed one long pulse followed by 16 short pulses. When the speed sensor wire was repaired, I only get the one long pulse - indicating everything is OK. I'm not 100% sure, but I think the 16 short pulses mean the fault is the speed sensor. At the time, I found some different nissan error codes on the internet (can't find them now) and they matched what I was seeing. I even tried disconnecting the AT oil temp sensor, to make sure it flashed the appropriate number of times for that, and it did. Hope this helps. Link to comment Share on other sites More sharing options...
solid snake Posted February 16, 2007 Author Share Posted February 16, 2007 I know bringing this topic back up is like flogging a dead horse, but, where do you find the speed sensor mentioned above. I still haven't been able to fix this problem, but in a week 1/2 this problem will be non existant. Link to comment Share on other sites More sharing options...
88pathoffroad Posted February 17, 2007 Share Posted February 17, 2007 It's on top of the transmission at the very rear. Link to comment Share on other sites More sharing options...
Kn0xville Posted February 18, 2007 Share Posted February 18, 2007 just wanna add my 2 cents since this was brought back up. I had the hard shifting problem/shifting at a high RPM's and crap just before my alternator crapped out on me.. I didnt have the codes flashing though. But replace the alty, and things have been fine. Link to comment Share on other sites More sharing options...
solid snake Posted February 18, 2007 Author Share Posted February 18, 2007 I just swapped a maxima alty and I haven't seen the flashes since then. before swapping it though, I poured in a bottle of lucas tranny additive, had the same hard shifting for a bit, but I eventually just ignored it since I was looking for the alternator. after the install I did notice it stopped, I didn't know if it was the additive or not. I haven't seen the tourque converter lock up anymore though since the problem started. When I release the gas at about 50, the revs just drop to about 2500 and no lock up. Link to comment Share on other sites More sharing options...
solid snake Posted February 20, 2007 Author Share Posted February 20, 2007 Ok got new info for all of you. I guess I would not needed to take it to the stealership to get it checked out anymore. When I finished doing the alty swap all the problems went away, just like Knoxville. Everything works great, overdrive torque converter locking up properly, and hard jerky shifting is gone. I don't know how modified knoxville's pathy is, as far as electronics is concerened, but if you take a look at my sig you can see what I have, beside a basic audio system set up. The dual fans are pulling 50 amps at start up and the stock alty is only rated at 70. Anyone care to have some sort of diagnosis to why this happend. What i was thinking is that there was not enough juice going to some sort of electronic component to the tranny and it was causing this problem. Link to comment Share on other sites More sharing options...
Pavelow Leaks Posted February 20, 2007 Share Posted February 20, 2007 That is really weird if the alternator is affecting the tranny. Link to comment Share on other sites More sharing options...
Kn0xville Posted February 20, 2007 Share Posted February 20, 2007 not weird at all. most auto trannies are electric shift. SO if your alty is bad, then you are running most things on the battery, there for not enough juice to electricaly shift your tranny. Link to comment Share on other sites More sharing options...
Pavelow Leaks Posted February 20, 2007 Share Posted February 20, 2007 That makes sense, I just checked, mine flashes 16 times too, also shifts hard, maybe I should get a new alternator. Link to comment Share on other sites More sharing options...
