water pump leak
Maz
Yeah I am a little pressed for time that's all. If I can just pull off the pump without changing or touching the tbelt that would be great. But if not I may be out of luck
Thanks
Jamie :furious:
Even if you can get it off with the timing belt on you risk getting coolant on the belt.
Coolant can breakdown the belt which would later lead to the belt breaking.. and if you are not sure what that means.. well lets just say that you will likely be in for a whole new engine or serious rebuild
change the H2o pump, t-belt and t'stat while you've got it apart. it won't take much longer to do it... set aside 4 hrs tops and you'll be good to go. :aok:
