NYpath Posted May 25, 2006 Share Posted May 25, 2006 i have a 98 SE....im looking to buy AR-767 15x8 rims and put BFGs AT KOs 31x10.50. will i experience some kind of rubbing in the front fenders? do i need to add a 2" coil lift with this combo or can i leave it stock? someone hook me up with some advice. im looking to purchase very soon....pics would be helpful, thanks!! :help: Link to comment Share on other sites More sharing options...
4x4le Posted May 25, 2006 Share Posted May 25, 2006 why not just lift it anyways? Link to comment Share on other sites More sharing options...
vengeful Posted May 25, 2006 Share Posted May 25, 2006 You can fit the 31x10.50x15 ATs on your stock rims just fine. As long as you get the 4.5" backspacing on the wheels, you'll be fine. Link to comment Share on other sites More sharing options...
zonianbrat Posted May 25, 2006 Share Posted May 25, 2006 I have 15x8 chrome wheels and 31x10.50 BFG At KO's on my pathy and I have not scrubbing or any other problems even when i go wheelin to problems at all. actually they look really good on the truck. but then again like 4x4le said why not lift it anyway???? I would have but was short on cash at the time. Link to comment Share on other sites More sharing options...
NYpath Posted May 25, 2006 Author Share Posted May 25, 2006 i plan on lifting it later and maybe 32s. i just want to change the look now cuz the stock look isnt my taste....the rim has a 4" BS. will the wheels stick outside the fender? thanks for replies, mad helpful. Link to comment Share on other sites More sharing options...
vengeful Posted May 25, 2006 Share Posted May 25, 2006 Yes, they will stick out. And if they stick out far enough, it may rub slightly at the forward edge of the wheelwell while turning in reverse. Link to comment Share on other sites More sharing options...
NYpath Posted May 25, 2006 Author Share Posted May 25, 2006 vengeful, will i have to remove the wheel well liners? Link to comment Share on other sites More sharing options...
NYpath Posted May 25, 2006 Author Share Posted May 25, 2006 does anybody have pics so my imagination can go wild :type: Link to comment Share on other sites More sharing options...
vengeful Posted May 25, 2006 Share Posted May 25, 2006 You won't have to remove them, but some trimming might be necessary. Don't go buck wild with the razor just yet though, wait until you get the tires on and see if it's even necessary. http://findapath.niora4x4club.com/az6 <-- Click here for a bunch of AZ Pics Link to comment Share on other sites More sharing options...
NYpath Posted May 26, 2006 Author Share Posted May 26, 2006 nice pics venge... Link to comment Share on other sites More sharing options...
PtownPathy01 Posted February 11, 2014 Share Posted February 11, 2014 I have a 2001 Se with a stock lift, I have a set of AR 15" rims wrapped with 31x10.50x15 M/Ts from a previous truck. Id like to use those tires..I plan on buy new 15x8 rims. But will 15" 6 lugs work, or will the not fit around the brake caliper and or rub!? I see some people say 15s will fit and others say i must use 16. PLEASE HELP! Link to comment Share on other sites More sharing options...
kdj Posted February 11, 2014 Share Posted February 11, 2014 The tire will fit in there no problem. My stock rims are 15x7(265x70R15) but 15x6(235x75R15) from a '96 won't fit over the rear drums. They'll go on there but they bind on the drum before they fit flush to the hub surface. Didn't try to see if they would fit over the discs(front). I have 31x10.5s on the stock 15x7 rims. I have no lift but lots of room. Hope that helps. You may want to try a search though, last post here was in 2006! Link to comment Share on other sites More sharing options...
