Guest IslaTurbine Posted May 14, 2006 Share Posted May 14, 2006 So my new 92 V6 Pathy didn't come with an owners manual. Can someone tell me how much oil the 3.0 takes? I'm assuming it's 5 qts. Thanks. Link to comment Share on other sites More sharing options...
packie88 Posted May 14, 2006 Share Posted May 14, 2006 5w 30 oil is recomended and its 3 5/8 qts on my 94, i installed a dual oil filter kit and im only putttin in 5qt to my engine. Link to comment Share on other sites More sharing options...
Guest IslaTurbine Posted May 14, 2006 Share Posted May 14, 2006 That's 3 5/8 qts including the stock oil filter?...or 4 5/8 with the filter? Link to comment Share on other sites More sharing options...
89_trailboss Posted May 14, 2006 Share Posted May 14, 2006 3 5/8 with Link to comment Share on other sites More sharing options...
Guest IslaTurbine Posted May 14, 2006 Share Posted May 14, 2006 Ok, thanks. Well I guess the ol' engine breather will be puking out some excess oil. Oh well. Link to comment Share on other sites More sharing options...
Slick Posted May 14, 2006 Share Posted May 14, 2006 (edited) Ok, thanks. Well I guess the ol' engine breather will be puking out some excess oil. Oh well. if you overfilled it i suggest you drain some oil out. it can be just as bad as having no oil at all and it will probably smoke too. how much oil did you put in it? Edited May 14, 2006 by Slick Link to comment Share on other sites More sharing options...
Guest IslaTurbine Posted May 14, 2006 Share Posted May 14, 2006 5 qts. You all have trouble reading the dipstick? No matter how much I wipe it off I can't tell the level. Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 14, 2006 Share Posted May 14, 2006 That's cause it's too high... Link to comment Share on other sites More sharing options...
Guest IslaTurbine Posted May 15, 2006 Share Posted May 15, 2006 Maybe, but it was doing that before I changed the oil too. And I didn't pull 5 qts outta her. Link to comment Share on other sites More sharing options...
RedPath88 Posted May 15, 2006 Share Posted May 15, 2006 That's odd, because the oil pan has a little sleeve that the dip stick/cable slides down into. It prevents the cable from angling off and also prevents splashing of the oil, giving an inaccurate reading... though the engine should not be running so slashing should not be an issue anyway. Link to comment Share on other sites More sharing options...
Slick Posted May 15, 2006 Share Posted May 15, 2006 how do you check your oil? cold? hot? running? i usually check it hot but motor off and i wipe the dipstick 3 times to get an accurate reading. Drain some oil out Link to comment Share on other sites More sharing options...
Slick Posted May 15, 2006 Share Posted May 15, 2006 That's odd, because the oil pan has a little sleeve that the dip stick/cable slides down into. It prevents the cable from angling off and also prevents splashing of the oil, giving an inaccurate reading... though the engine should not be running so slashing should not be an issue anyway. i can tell you from VERY recent experience that if it's too full you will have no end of trouble reading the dipstick as 88 said.. drain a couple qts out n try again Link to comment Share on other sites More sharing options...
RedPath88 Posted May 15, 2006 Share Posted May 15, 2006 as 88 said.. drain a couple qts out n try again Yup, to much is a bad thing... drain the extra -thnkboutit- Link to comment Share on other sites More sharing options...
Guest IslaTurbine Posted May 15, 2006 Share Posted May 15, 2006 I'm gonna drain a lil' bit out tomorrow. BTW, I check my oil cold w/o the engine running and usually wipe the dipstick about 2 times. Thanks for the input. Link to comment Share on other sites More sharing options...
Slick Posted May 15, 2006 Share Posted May 15, 2006 I'm gonna drain a lil' bit out tomorrow. BTW, I check my oil cold w/o the engine running and usually wipe the dipstick about 2 times. Thanks for the input. check it at working temp with the motor off Link to comment Share on other sites More sharing options...
