R50 bearing removal
turbopath
Ok, I'm trying to get the little needle bearing out of the end of the spindle/knuckle. The one that the CV shaft rides in. Since the spindle is so long I can't knock it out, so it looks like it has to be pulled. Any tips on getting this thing out?
i had a think about this on a d21 the other day.
didnt do it. however my conclusion was you would require a internal bearing puller and a bit of effort.
sorry, not really anything constructive, just thought.
i just gave up - cleaned it out with compressed air and a rag. then went nuts with grease and my fingers. pushed as much grease between and in the needle rollers as humanly possible.
maybe not those needle roller bearings then.
have you checked the two main wheel bearings? clean and re-grease?
Ya, I replaced everything including the spindle. Problem is...the junkyard spindle has a bad needle bearing.
  • 4 years later...
