Equus 3030 OBD II Car Reader
Trainman
UPDATE April 11/06:
So had the code read at the local shop today, they use the latest SnapOn reader. Could not read for an 02 or 03. No data available from Nissan. Could not even re-set the light.
So, will the cheapie ones work? :shrug:
Will the Equus 3030 OBD II Car Reader read the SES codes on the 02 Pathfinders?
Edited by Trainman
It wouldn't be OBDII if it were non-standard. I've used generic code readers on all kinds of vehicles, newer Pathfinders included. Works fine.
Thanks, I must have had too much wine last night when I was thinking/posting that :lol: -alcohol- -alcohol-
Is there an issue with Nissan using some codes that are not standard? :shrug:
Trainman, you're somewhat right. OBDII codes starting with P0 are generic and will be the same for any OBDII vehicle. Codes starting with P1 are manufacturer specific and might use a different meaning for the same code number. If the Equus code reader includes text descriptions of the codes, you'll need to translate them to the Nissan meaning if they are P1 codes. But any OBDII reader will still be able to read the actual code numbers.
For example:
P1110 - OBDII generic code is Intake Air Temp. Sensor
P1110 - Nissan specific code is Intake Valve Timing Control
the book it comes will have a lot of the codes in it, mfg specific, i know my dads OBD2 book has a section for each of the common MFGs but sometimes it throws a code thats not in the book and you have to call nissan or whoever to call it, my dad is professional mechanic so he gets his fair share of that stuff
For example:
Thanks, so I was not like totally confused, only partly. :P
It comes with some sort of cd that has a bunch of info. The web site is a little vague on this and the Canadian Tire parts guy does not have a clue.
UPDATE:
So had the code read at the local shop, they use the latest SnapOn reader. Could not read for an 02 or 03. No data available from Nissan. Could not even re-set the light.
My neighbor has a cheap one and it worked on my 01...
Apparently it is the 02 and up. Nissan does not release the code data for 4 years, so 01 would work (it did at the shop) but 02 and younger right now will not.
