4x4 starter replacement
Guest 95path addict
Guest 95path addict
Replaced a starter on 2wd pathy but never on 4wd , just wondering
how bad it is to change. I think mine is about to go out , when you hit the key
it sometimes hesitates before spining , checked all other connections .
there are people who have said it not much of a problem and there are those who have needed to disassemble the starter just to remove it. Use your search button and read up. Best of luck with it. If you discover any tricks or such, please post so that others may benefit from your experience.
