02silverpathy Posted February 20, 2006 Share Posted February 20, 2006 (edited) SO OK, My new tires rub (R50 w 265/75/16 Revos...OME lift with front spacers). They rub all the time! Lol, will I give up? Hell no! I am ordering .25" wheels spacers tomorrow and spline drive lugs...my question is has anyone else done this and/or has anyone bought the ARP extended wheel studs??? The tires rub against the strut/coil tower. Grinding is not an option due to the fact that the current surface is rubbing but smooth and I think if I grind it it may not be as smooth...plus that cures a sympton not a cause. I will post pics before I get vandalized with that cute "this post is worthless without pics" banner!!! I am going to take clean pics and upload tomorrow!! edit: only the front rubs...and I know---->if I had T-bars that wouldn't happen Edited February 20, 2006 by 98silverpathy Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted February 20, 2006 Share Posted February 20, 2006 I can tell you what is going to happen next but that would be pointless. Link to comment Share on other sites More sharing options...
Simon Posted February 20, 2006 Share Posted February 20, 2006 Pezzy had the same issue, and had to go with aftermarket wheels with less backspacing to cure her issues. I'd say wheel spacers are a bad idea, especially if you're only going to use them in the front........as it will throw off your steering geometry and cause some oversteer. Vsicks. Why not stop being so vague, and post what you believe his issues will be. Your post is useless as it sits. Link to comment Share on other sites More sharing options...
Pezzy Posted February 20, 2006 Share Posted February 20, 2006 Yes, I've heard a lot of negative feedback about wheel spacers (even here -- try a search)... my Revos are 275/70/R16's, and I fitted them on the offset AR 767's right away, as the space between the tire & strut mount was pretty slim with the stock tire. Vsicks, I have to agree, if you can share info that will help, I am sure there are some of us willing to learn. Link to comment Share on other sites More sharing options...
02silverpathy Posted February 26, 2006 Author Share Posted February 26, 2006 Got the wheel spacers..installed the wheel spacers...had to modify the wheel spacers...........they wouldn't fit over the 4wd hub...cut them open installed them, put new gorilla extra deep lugs on...all is safe and not rubbing for now!!! Link to comment Share on other sites More sharing options...
02silverpathy Posted February 26, 2006 Author Share Posted February 26, 2006 (edited) Check the tolerance...whew that's close...can you tell where it rubbed??? I am thinking that I will order another set of spacers and get the extended arp wheel studs...what so you think??? I ask because the way that the R50 suspension works, the strut is at an angle so it will compress up into the frame work, away from the tire but anyhow all ideas are appreciated!!! ps........I love these tires!!! Edited February 26, 2006 by 98silverpathy Link to comment Share on other sites More sharing options...
88pathoffroad Posted February 26, 2006 Share Posted February 26, 2006 Take an angle grinder to the edge of the strut and clearance it instead of using more wheel spacers. Link to comment Share on other sites More sharing options...
Guest 05thumpinpathy Posted February 27, 2006 Share Posted February 27, 2006 my pathy came stock with P265/70R16 tires...im upgrading soon to 305/40/r22...ya sorry im goin the other way with this one...but dont worry once i get some bills payed up im getting another pathy...def an r50 so i'll be taken it wheelin...i miss doin it... Link to comment Share on other sites More sharing options...
02silverpathy Posted March 24, 2006 Author Share Posted March 24, 2006 Alright back from near death...posted pics if the wheel adapters (since the silly spacers just weren't far enough away!). These are more billet aluminum with their own studs...so they bolt up like wheels and then bolt your wheels to them! Link to comment Share on other sites More sharing options...
02silverpathy Posted March 24, 2006 Author Share Posted March 24, 2006 wide rear--look at dat a**! Link to comment Share on other sites More sharing options...
02silverpathy Posted March 24, 2006 Author Share Posted March 24, 2006 another from the back...that's just how I likes it! can you say "I'm in love with a finder (stripper)" Link to comment Share on other sites More sharing options...
02silverpathy Posted March 24, 2006 Author Share Posted March 24, 2006 Aww she's growing up?! Her tires just make it for MD piggies! I am allowed 1/4" outside of any fender flare as long as it is not considered tread (that makes it sidewall). Link to comment Share on other sites More sharing options...
02silverpathy Posted March 24, 2006 Author Share Posted March 24, 2006 So these are 1.25" spacer adapters and they did change the way the truck handles...the more I toy with this the better I dig off/on ramps!!! Can you see my little Honda in the reflection...these two are good friends, but it seems the Honda is moving to California! Maybe I can have another friendly animal in the stable this fall, huh? Link to comment Share on other sites More sharing options...
87pathy Posted March 24, 2006 Share Posted March 24, 2006 I can tell you what is going to happen next but that would be pointless. so you are saying that we are all too stupid to understand? or just trying to make people think you are smarter than you really are? Link to comment Share on other sites More sharing options...
