300 ZX Headers
Chupacabra
I haven't checked, but I'd doubt it or else it would've been mentioned on at least one of the boards I look at. Try posting your question on nissan4wheelers.com. Those guys do a LOT of fabrication and mods. If someone's done it, they'll probably have heared about it.
If you're talking about the 80's Z31 300ZX, no, they will not fit. The rear most primaries on both sides will hit the firewall. You would have to modify them. There are already at least two options for the Pathfinder though - PaceSetters or Thorley's.
Yeah, IIRC the crossover pipe goes over the tranny also, instead of under like on our trucks. Might work with a BL and a good hammer P...:shrug:
Nah - that's only the turbo model that has the crossover pipe over the transmission.
Well, the NA ones from 90-95 have the same VG30E but with different FI setup and ECU. The 86-89's had VG30E's while 86-89 Pathys have VG30i's. Same block up till they went to a DOHC design for the Z32 line. I don't know that much about 300ZX's tho.
