New to Pathfinders- wiper issue and others
Guest whitebb
Guest whitebb
I noticed my wipers turn themselves on occasionally with no notice. I suspect the intermittent relay or switch. Where is the intermittent relay located?
i must clear off the 1447 code. I nedd to order the charcoal canister and valve from
Guest whitebb
Pinnacle Nissan. I emptied the charcoal, and blew out the lines, which deleted the 1441 code.
Next I need to replace the front struts and tires and get an alignment and this thing will be rolling again. The front struts were replaced 2 years ago with Monroe sensatracs, as were the rears.The rears were dead and replaced with Gabriel Ultras. I will do the same with the fronts.
Your help on the relay is appreciated. I am a diehard Ford and Chrysler man thats trying to adjust.
Ok, so it's an R50... (1996-2004?) Yours is a 1997 with 175K... I can't help you much as I have a 95, a totally different animal. These are a bit different than the US made stuff, but many prefer them. :shrug:
I'm moving this to the R50 section... Welcome and good luck !!
