leojharris Posted January 11, 2006 Share Posted January 11, 2006 hi there... My instrument panel is going flaky on my 95 XE and I was going to buy a new voltage regulator from Nissan ... however ... the parts guy at the dealership says there is *no* voltage regulator on the 95 XE. any idea if this is true? he says he shows a part up to the 94 but not the 95. if this is the case, what are the options, drop 200 bucks on a new cluster or fix existing? i'm not much of an electric guy. thanks. .joel. Link to comment Share on other sites More sharing options...
Mookie Posted January 11, 2006 Share Posted January 11, 2006 '93 and newer don't have the gauge voltage regulators like the older ones. I think they are built right into the gauges. Check on that and maybe see if you can get the gauges separately? I'm not familiar with the newer dash setups, so someone else will probably post up. Link to comment Share on other sites More sharing options...
leojharris Posted January 11, 2006 Author Share Posted January 11, 2006 did some more research and the parts guy says the only thing he offers is a circuit board type thing for 45 bucks. don't know if it is what i need or not. basically, the speedometer is out almost 95% of the time and the check engine light stays lit; also, at these times, the odometer doesn't work. other gauges look questionable but close to what they should read. the few, very rare times that the speedometer works, it only barely works and the check engine light gos off. anyway, i found a couple instrument clusters at salvage yards but don't know if I should trust them. Link to comment Share on other sites More sharing options...
88pathoffroad Posted January 12, 2006 Share Posted January 12, 2006 The voltage regulator only runs the fuel and temp gauges, guys. Go read the FAQ's. If you ONLY have a speedo/odo problem, it's more likely to be the speed sensor on the tranny, don't you think? Link to comment Share on other sites More sharing options...
Mr. Pickles Posted January 12, 2006 Share Posted January 12, 2006 Try the Meter fuse under the dash. If not that, run the engine codes after driving, as the speed sensor will spit a code. If that doesn't help, proceed along your path. Link to comment Share on other sites More sharing options...
leojharris Posted January 13, 2006 Author Share Posted January 13, 2006 spent most the day running around salvage yards ... what i've found is that the pathfinder instrument cluster on the 95 is completely different than earlier models; it has independant gauges that you have to purchase seperately from nissan if you want to replace them; otherwise, the option is to find a complete cluster from salvage yards. the much refered to and very well done solution page for the voltage regulator issue does not apply to a 95 pathfinder. as someone said, it's all built onto each head (speed,rpm,etc.) and you have to purchase each head seperate. i've ended up with a spare instrument cluster and will take some photos and post them soon; it has this strange, plastic circuit board type thing linking all the lighting mechanisms. as it turns out, most of the clusters i checked were in some way whacked out like my own; but finally i found one that works near perfect for 30 bucks. (the speedo head alone costs 200 from nissan). this has solved the problem. no more engine light and the speedo and everything works. onlyl thing is the gears on the odometer have a slight hang up every 8 10ths of a mile or so. tried to put some very low visc oil on them but hasn't helped much. i'm stoked it wasn't the speed sensor as i doubt i could have found one salvy and didn't want to buy new. anyway, learned a lot breaking everything apart and will try and take some photos soon. thanks for the assist. .joel. Link to comment Share on other sites More sharing options...
Precise1 Posted January 13, 2006 Share Posted January 13, 2006 Thanks for the info !! My speedo has been whacking out intermittently for a few months (getting worse) and just the other day the gas gauge failed (but it came back to life today). I'm hoping when I get into it, it's just something loose, but from your discription, it is not... No pathy's in the wreckers around here... We'll see that happens. B Link to comment Share on other sites More sharing options...
Mr. Pickles Posted January 14, 2006 Share Posted January 14, 2006 No pathy's in the wreckers around here... We'll see that happens. B Post up if you're still looking B. I've run across a few Pathys here, some with gauges seemingly intact. Link to comment Share on other sites More sharing options...
