chapter Posted January 6, 2006 Share Posted January 6, 2006 In my previous path 90 I had an inverter 600W in the cargo bay screwed on the right side. I want to have it in my path 2002 but I can't find where??? Is anybody has already install an inverter of 600 - 1000W, so directly connect on the battery (not in the 12V outlet plug!!!!) Thanks. Link to comment Share on other sites More sharing options...
lowrider Posted January 6, 2006 Share Posted January 6, 2006 run a wire. fuse it. ground it terminate it mount it. Link to comment Share on other sites More sharing options...
XPLORx4 Posted January 6, 2006 Share Posted January 6, 2006 To install the inverter in your '02, just repeat the steps you took to install it in your '90. (Pretty much what lowrider said.) Link to comment Share on other sites More sharing options...
merlinx Posted January 7, 2006 Share Posted January 7, 2006 I actually spliced into my power wire for my amps and placed the 1000w inverter next to all the amps on the back of the back seat. so far no problems and it seems to power just about anything. Link to comment Share on other sites More sharing options...
chapter Posted January 7, 2006 Author Share Posted January 7, 2006 Merlinx, Where you run the wire?? Link to comment Share on other sites More sharing options...
t0ast Posted January 8, 2006 Share Posted January 8, 2006 (edited) If you don't have a manual tranny, there's a plate that covers where the clutch is supposed to be in the firewall. Pop that out, drill a hole through the plate, and run the wire through. Edited January 8, 2006 by t0ast Link to comment Share on other sites More sharing options...
Newton Posted January 9, 2006 Share Posted January 9, 2006 Just a quick question, what kind of goodies will a 1750 W inverter run? Link to comment Share on other sites More sharing options...
merlinx Posted January 9, 2006 Share Posted January 9, 2006 I just ran a wire through the main wire harness boot. Had it for a while no problem. Link to comment Share on other sites More sharing options...
