parthy Posted December 31, 2005 Share Posted December 31, 2005 high guys having trouble finding any spots with rubber gromets to run wires from the cab to the engine bay do you have to drill a hole and if so what would be the best spot :secret: Link to comment Share on other sites More sharing options...
Pezzy Posted December 31, 2005 Share Posted December 31, 2005 hmm... I found a spot on mine... was on the driver's side maybe 6" down from the top - there was a flat circle of metal screwed to the firewall... when I unscrewed it there was a hole to the inside - came out under the dash - high up in the foot well, although not very big - but I was able to run a few wires thru... it's not watertight now - not without some silicone... Link to comment Share on other sites More sharing options...
parthy Posted December 31, 2005 Author Share Posted December 31, 2005 thanks pezzy found that spot but they have put a computer box or somthing over the top of it didn't want to run anything to close to it (uhf or cb ) in case it @!*%'s it's self Link to comment Share on other sites More sharing options...
deej Posted December 31, 2005 Share Posted December 31, 2005 Here ya go http://www.nissanpathfinders.net/forum/index.php?showtopic=2513&hl= Link to comment Share on other sites More sharing options...
parthy Posted December 31, 2005 Author Share Posted December 31, 2005 Thanks man I will check it out Just have to remember the steering wheel is on the other side -thnkboutit- Link to comment Share on other sites More sharing options...
Trainman Posted December 31, 2005 Share Posted December 31, 2005 Here ya gohttp://www.nissanpathfinders.net/forum/index.php?showtopic=2513&hl= In addition to his, if yours is an automatic, you can run it thorough the hole used for the clutch. It has a plated held on by 2 bolts that you can undo and get wires through. Be careful pulling them though as they will rub on raw metal. high up in the foot well, although not very big - but I was able to run a few wires thru... it's not watertight now Not sure I would want to go that deep in water with out some other items, like a submarine :allclean: Link to comment Share on other sites More sharing options...
FUELER Posted December 31, 2005 Share Posted December 31, 2005 like he said, main wiring rubber grommet. I also drilled a hole next to the metal grommet for my 6 gauge power cable. Link to comment Share on other sites More sharing options...
