packie88 Posted December 9, 2005 Share Posted December 9, 2005 found out a little awhile ago that i have a main oil seal leak. not big enough to wear its affecting the vehicel but its still there. just wondering what my options are. because to get it fixed im pretty sure that i haev to pull the engine. Link to comment Share on other sites More sharing options...
k9sar Posted December 9, 2005 Share Posted December 9, 2005 I know someone who poured a container of radiator stop-leak into their oil in hopes of stopping the oil leaks. need I say more? DON'T DO THAT! Link to comment Share on other sites More sharing options...
packie88 Posted December 9, 2005 Author Share Posted December 9, 2005 i dont plan on doing that, and im not that stupid theres a reason it says "radiatior stop leak". i mean as of now its not really threating to the runnign of the pathy. but im jsut starting to look for my options for the future. Link to comment Share on other sites More sharing options...
k9sar Posted December 9, 2005 Share Posted December 9, 2005 (edited) was not implying that you would even consider it. was also amazed at my buddy's level of stupidity. personally, I like oil leaks. Keep it topped off and you extend the time between oil changes cause you're always adding fresh. hehehehe Edited December 9, 2005 by k9sar Link to comment Share on other sites More sharing options...
packie88 Posted December 9, 2005 Author Share Posted December 9, 2005 lol good point. speakign of which u reminded me i need to do an oil change Link to comment Share on other sites More sharing options...
94extreme Posted December 9, 2005 Share Posted December 9, 2005 was not implying that you would even consider it. was also amazed at my buddy's level of stupidity. personally, I like oil leaks. Keep it topped off and you extend the time between oil changes cause you're always adding fresh. hehehehe aha! you do work for exxon. Link to comment Share on other sites More sharing options...
Precise1 Posted December 9, 2005 Share Posted December 9, 2005 I like oil leaks. Yeah, real nice... Polute and create hazzards for motorcycle riders... Real responsible. Even my VW Bug doesn't leak oil ! B Link to comment Share on other sites More sharing options...
Tinker Posted December 10, 2005 Share Posted December 10, 2005 A slight increase in oil weight may be an option if you're not in an area affected by extreme low temperatures (10w40, 20w50, straight 30W, etc) and may result in a slight decrease in leak rate. Do not change to a heavier oil than recommended in the manual if you live in a cold area - tough to crank an engine full of molasses! Additives like stop leak (engine, not rad!) may provide temporary relief, but have been known to cause seal deterioration after extended periods (and not just the seal that was leaking - think every seal in your mill!). In general, your options are: 1)replace the seal, 2)drip and fill, repeat as necessary, 3)ignore it - it'll go away when the engine seizes due to lack of oil! Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted December 10, 2005 Share Posted December 10, 2005 Get it fixed asap. that leak will kill bikers on the road, pollute, and leave a huge mess under your truck and driveway. Trust me I know... Link to comment Share on other sites More sharing options...
Geeky907 Posted December 10, 2005 Share Posted December 10, 2005 Sorry to sound ignorant here (but what else do you expect from the new guy)..... but most the "motorcycles" around here have atleast a 8inch wide tire on em.... and most of my oil-leaks leave a single dime-sized drip every couple miles..... how is this dangerous to motorcycles? and is this any more dangerous then riding a VERY modified Crotch-rocket without a helmet in a tank-top and cut-off's at 100+mph on busy/crouded highways??? - Geeky907 Link to comment Share on other sites More sharing options...
Precise1 Posted December 10, 2005 Share Posted December 10, 2005 Geeky, yes, most bikes have 'large' tires... In the rear, with the front being 1/2 the size. None of this really matters due to the tires being radiused. Motorcycles ride on a contact patch of a few square inches, thats it. Riding a bike is a symphony of ballance, gyro's and traction. Remove traction from the equasion and it generally means a crash ! Yes, maybe you only drip a little bit, but you stop at a freeway off ramp light and drip a few drops. So does the 10th guy, and the 20th, etc. Along comes a motorcyclist, leans to turn and down he goes if he is unlucky. I have crashed twice due to fluids on the road; first time resulted in a dislocated shoulder, second just bruises and cosmetic damage to the bike. I have hit oil/antifreeze at least 10 times... Crotch rockets are the safest bikes to ride as they handle and stop the best, but yes, the idiots who dont wear protective gear much less helmets (shudder) are just asking for it ! B Link to comment Share on other sites More sharing options...
Geeky907 Posted December 13, 2005 Share Posted December 13, 2005 WHy thanks for the education there, i just wasnt aware... i guess it makes sense... just never really thought about it... - Geeky907 Link to comment Share on other sites More sharing options...
Precise1 Posted December 13, 2005 Share Posted December 13, 2005 just never really thought about it... Without making it specific to you, yes thats the problem. Most people dont think. I worked with a guy who had a leaky autotranny; 1 qt a week at least. When I heard him laughing about just dumping more in all the time I clued him in... To his defense, he pulled the tranny and fixed the leak with in 2 weeks after driving like that for months. Next time you have the opportunity, watch to see how careful a motorcyclist is at a toll stop (like a bridge or something). The area is so slick from leaky cars it is unreal. I can start from a stop in 2nd or 3rd and lay a smokie for 1-200 feet without trying due to how slick the pavement is... B Link to comment Share on other sites More sharing options...
