when i lift my pathy, what about the radiator?
nakta
hmm.. musta missed the memo on that one.. mine's a one piece... there again.. previous owner did a little facial discredit to my Pathy at one point in her life...
but won't the shroud hit the fan once my radiator is 3 inches higher? i did not get the drop down kit. should i wait an dget the kit, or is it better without it? where do i buy the kit?
Just take your shroud off. You do not need it unless you are going to do some SERIOUS prolonged low range 4wding.
You don't have to do any full removal or relocating of the shroud or radiator!! Just remove the small portion of the bottom of the shroud that runs around the bottom of the fan. It just snaps into place (at least on mine- a 94). After that, there is plenty of clearance, and no overheating problems, and I've driven mine from freezing to 100 degrees on monster climbs with no problems.
Edited by Mr. Pickles
