Guest peeny420 Posted June 4, 2005 Share Posted June 4, 2005 Hi all, I just bought a 1994 SE a couple of months ago. Its dark green (almost black) and came with the running boards, tire carrier, roof racks, and factory alarm system. I absolutely adore this truck as I have wanted one for twelve years. The first thing I had to do to it was plane the drivers side exhaust manifold and replace the studs (I'm sure the passenger side is to come later). I have been having problems with the check engine light coming on intermittently. It seems to come on more when I am on gravel roads then when I am in town. I checked the ECU as per instructions I found on the site and got a code 33 in mode 3. I also checked out mode 1 and got about one blink per second on the green led. The final symptom I have had has been an erratic idle while at stop lights similar to what others in the forum have described, this has happened 2 times. once when I was on my way to get the manifold fixed, and once after having my oil and air filter changed. I was just wondering if anyone had any wisdom for me on where I should start. I've been thinking O2 sensor. any help would be appreciated. Link to comment Share on other sites More sharing options...
Pezzy Posted June 4, 2005 Share Posted June 4, 2005 Welcome to the board... I'm sure you will find help here! Link to comment Share on other sites More sharing options...
DJ Dank Posted June 4, 2005 Share Posted June 4, 2005 Hey welcome to the message board. Check out the forum pertaining to your year Pathy! Link to comment Share on other sites More sharing options...
Trainman Posted June 5, 2005 Share Posted June 5, 2005 Welcome! You will find lots of good info here. What part of Lotus Land are you from? Link to comment Share on other sites More sharing options...
Guest peeny420 Posted June 5, 2005 Share Posted June 5, 2005 I am from Comox which is located on Vancouver Island and I work in aquaculture on the northern tip of the island close to Port Hardy. We have tons of deactivated logging roads here so the wheelin is good. I am a very active hunter and hiker so I expect the Pathy to come in very handy. Link to comment Share on other sites More sharing options...
Pezzy Posted June 5, 2005 Share Posted June 5, 2005 We went thru Comox on our honeymoon... stopped on our way back to the mainland. Beautiful country out there! Link to comment Share on other sites More sharing options...
Trainman Posted June 5, 2005 Share Posted June 5, 2005 I grew up on the Island and worked for one of the logging companies so know about the great roads . I did quite a bit of work in the Trent River valley in the mid to late 80’s. I design and supervise road deactivation projects (among other things forestry) so I know what that is all about! Great area for exploring, have fun. Link to comment Share on other sites More sharing options...
