Crank No start rpm won’t lift
ThatOneNissanGuy
I was driving back from work then had to come to a stop on a red light and the truck started idling at 2k rpm i moved the mtps as low as possible and it was then at 1.2k at home i resetted the tps to factory position and just adjusted the idle screw now it idlesll at 800 rpm stopped but then when you're in neutral or press the clutch while moving anywhere past 5mph it revvs to 1.5k and when you revv it and lift of the throttle in neutral the truck drops to 425~ rpm before jumping back to 800, today I tried going to work and it just cranked and didn’t start the dizzy cap was shot so I bought a new one, it didn’t work so
i bought an ignition module and coil but turns out it might be the ckp but where is the ckp
VG33E FS5R30A
Edited by ThatOneNissanGuy
New issue
