R50 Radio Power issue
2003 R50 with OEM 6 disc changer and cassette player/radio would not power on.
Pulled the radio fuse (fusebox on left side of steering wheel), still good, reinstalled fuse.  Turn on key, radio still won't power up.
Pulled the 'amp' fuse (fusebox on left side of steering wheel), was still good, upon reinstallation of amp fuse the 6 disc changer start cycling through 6 disc holders -even with the key off(well, ...90% sure the key was off)
Turned on key and the radio powered up.
No idea why, but radio works again (cd died ages ago, probably laser or laser transport is broken)
Not sure what the question is, but yeah, the amp fuse is confusingly the one that controls power to the stereo. Back when I had it, I had to pull that fuse sometimes after I modded the cassette player with an AUX input. The cassette deck "thought" there was a cassette stuck in it at random times which necessitated the good old fuse reset.
My guess is that your amp fuse was loose or is glitchy or something else in the fuse box is wrong (corrosion, loose wire, bent tabs).
Yeah, strange that pulling and reinserting the fuse fixed it.
Maybe something loose in the fuse box, though everything is stock and the vehicle is stored in a dry environment.
22 years old, so odd things can happen....
I remember my dad's '03 doing something similar. Pulling a fuse (don't remember which one, this was over a decade ago) and putting it back brought it around temporarily, until it crapped out again. I think replacing the head unit was what got it in the end.
I would try unplugging the CD changer, especially if it's dead anyway. See if that clears up the issue with the head unit. Maybe the changer was locked up, and the head unit was waiting for some signal from it? The '03 service manual should offer some system troubleshooting, and at least tell you what all is wired to the amplifier fuse, which might offer some hints.
Will try that should the unit fail to power up again!  Disconnecting the CD unit could save the radio...
Just fyi, in my case the entire radio/cd/cassette seemed to be not be getting any power, display would remain off when hitting the power button.
Edited by sonyslave
  • 5 months later...
I have the same problem, 2003 SE with BOSE Audio. The radio would not start, I would remove and reinstall the amp fuse and it starts after that.
I solved the problem for at least a year after buying new quality Japanese fuse and installing it instead of original one (which is still fine but had brown coloured legs).
Now it started again, don't know how to remediate it, if there is a connection issue in the fuse box, why it starts right away?
I think it's related to the unit itself, it causes some condition that only "fuse restart" helps.
Who has/had this problem, have you also that it could cause parasitic draw? Now it started again, my battery dies sometimes when car is parked for several days. Do you think there could be a connection between these two problems?
Also I don't use either cassette or cd player, only radio. Do you know if it's possible to disable CD and cassette feature in the head unit?
