Ripple Posted October 17, 2024 Share Posted October 17, 2024 I have an 04 pathy which I suspected had a blown head gasket. I went ahead and pulled the engine and as I took it apart I found many more issues and decided to swap in a new motor. I was able to get my hands on a 02 3.5L engine with low miles for a good price but I am aware that there are some subtle differences between my 04 engine and this 02 engine. I was wondering what I needed to swap over to my 02 engine in order to make it work for me. I'm having a hard time finding info on this so any links would be greatly appreciated. Link to comment Share on other sites More sharing options...
Foolstival Posted October 18, 2024 Share Posted October 18, 2024 Ooh, engine swaps can be tricky. I did something similar with my old Toyota, and it was a bit of a headache. Make sure you document everything as you go along - take lots of pictures and label all the parts. Good luck with your project! Link to comment Share on other sites More sharing options...
Slartibartfast Posted October 18, 2024 Share Posted October 18, 2024 I don't know the VQ, but I'm told a bunch of stuff changed between '01/'02 and '03/'04, enough that it may be less work to track down a later donor than to get what I'm assuming is a cable-throttle engine working in a drive-by-wire truck. (I don't know offhand when that changeover happened--if it was mid '02, and the donor was late '02, you may be in better shape than I'm assuming here.) I use the parts lookup on nissanpartsdeal a lot to work out when parts were used. Might help with working out part compatibility. CamperDan mentioned the cam phasers--look those up for '02 and '04 and see if it's the same PN. As usual I'll plug the factory service manuals. Free download from Nicoclub. EM and EC sections will come in real handy for this. There's some good info in there if you can wade through all the hand-holding for using special scan tools that you don't have. And yes, do take a bunch of pictures, both for your own reference and to help the next guy who asks the same question. 1 Link to comment Share on other sites More sharing options...
hawairish Posted October 18, 2024 Share Posted October 18, 2024 "Subtle differences" is the right term here. I would expect needing the upper intake plenum and electric throttle body. I would expect wanting the lower intake plenum as the 01-02 were prone to have loose power valve screws, unlike the 03-04...not that you can put some thread locker on them. (Speaking of which, you should tear down that 02 intake to confirm all power valves AND screws are present and not loose, in case that engine was pulled for some other reason). You'll want to check the camshaft position sensors between both engines. When I was last pulling parts from the junkyard, I want to say the sensors are different and in different positions, not to mention I think there's on less sensor or sensor hole on the newer engines. I'm forgetting a detail here, but probably easily to resolve. I think beyond those items, there isn't really all that much else? 1 Link to comment Share on other sites More sharing options...
