Brake booster
SamoYU
Hello
I have issues with my brakes on my WD21 2.7TD
, i changed front calipers and bled the system and all is well, but just after a 20km drive a have zero brake pressure on the pedal and when i do its pulling hard to the right, i am not leaking any brake fluid though, not a single drop. Is the problem in the brake manifold?
Also i wanted to ask if a brake booster from terrano 2 or maybe a patrol would work as a replacement for mine, on pictures they seem familiar.
Thanks for the help.
Kind regards
Samo
Are your calipers on the right sides? Bleeder should be at the top to eliminate airlocks.
Sounds like you have air in your system.
Check Caliper orientation, check fittings, re-bleed to ensure all air is out of the system.
Sounds like something is wrong with the left front caliper. I would check that a pad hasn't fallen out or something. Might check the rubber line too.
No idea on the boosters, we don't have either of those in the US.
Sorry for late response I am on a vacation.
Yes i ordered repair kit for master cylinder along with new brake pads and discs (the left one is badly worn due to seized caliper). I will change all of this and bleed the brakes once again and hope for the best :), i have also ordered new brake shoes for aft brakes.
I will try to find some info about the booster but I checked and search quite a bit and found nothing for now :/.
Kind regards
Samo
