92Path_68CJ Posted February 20, 2024 Share Posted February 20, 2024 Wanted: Fog light connectors for the WD21. Anyone have the male end (attached to the fog light) in good shape off the factory Bosch foglights for the WD21 they'd let go? New ones are like 20-30$ a connector. I'd like to wire some non factory lights into the factory harness and if anyone has some in good shape I'd be interested in purchasing them. I only need the connector that comes off the factory foglight, I don't need the factory foglights themselves, or the harness that goes in the car. Link to comment Share on other sites More sharing options...
adamzan Posted February 20, 2024 Share Posted February 20, 2024 Do you have a picture of them? Might be able to get it from one of those large electrical suppliers like digi-key. They are probably a somewhat common weatherpak connector. Just doing some checking, you can probably match it up at the parts store if no one has any laying around: https://www.amazon.com/Pathfinder-1987-1995-Foglight-Assembly-NI2592113/dp/B074QGQ8JZ Link to comment Share on other sites More sharing options...
92Path_68CJ Posted February 21, 2024 Author Share Posted February 21, 2024 12 hours ago, adamzan said: Do you have a picture of them? Might be able to get it from one of those large electrical suppliers like digi-key. They are probably a somewhat common weatherpak connector. Just doing some checking, you can probably match it up at the parts store if no one has any laying around: https://www.amazon.com/Pathfinder-1987-1995-Foglight-Assembly-NI2592113/dp/B074QGQ8JZ I appreciate the suggestion, I have one set already I used to wire some lights to the stock fog light harness. I checked online and some places through my work, but the connector is pretty darn uncommon from what little I've seen. Autozone "makes it, but one is 34$. I broke the original fog lights years ago and saved the wiring knowing I would do something with it eventually, Im hoping maybe someone will have done something similar. I'm not in a big hurry, but I do wanna continue to use to stock wiring. It's already there. https://www.autozone.com/electrical-and-lighting/fog-light-connector/p/duralast-electrical-wire-connector-275/ Link to comment Share on other sites More sharing options...
92Path_68CJ Posted February 24, 2024 Author Share Posted February 24, 2024 If anyone ever finds themselves looking for these connectors because they also want to reuse the factory harness. Use part number: 12015792 Delphi Weather Pack Someone on the facebook group managed to reverse image search for them online. I'll just order new connectors 1 Link to comment Share on other sites More sharing options...
