Oil change 90 pathfinder
Taericko
If the bolt head was on the bottom, it would tend to catch on things. And the threads would still have to extend into the pan, so there would still be some trapped oil, unless the threaded part was below the pan, which would make it stick down more into harm's way.
But yeah, if you jack up one side, you can get a little more out.
