JB3829 Posted May 10, 2005 Share Posted May 10, 2005 Yo guys, any info on changing the transfer case and differential fluid? I was thinking about using synthetic. Does the transfer case have a drain plug? Thanks! Link to comment Share on other sites More sharing options...
94extreme Posted May 10, 2005 Share Posted May 10, 2005 it better.. synthetic is good. may want to purchase a repair manual for your model.. it has capacity charts and lots of other usefull info.. Link to comment Share on other sites More sharing options...
XPLORx4 Posted May 10, 2005 Share Posted May 10, 2005 Yes, you can use synthetic ATF in the t-case, which has both a drain and fill plug. I put Mobil1 ATF in my t-case. When replacing drivetrain fluids, ALWAYS loosen/remove the fill plug before the drain plug. You don't want to drain the fluid only to find out you can't remove the fill plug! Link to comment Share on other sites More sharing options...
02silverpathy Posted May 10, 2005 Share Posted May 10, 2005 xplor4x...took the words out of my mouth!! always need to be prepared for the worst!!! Link to comment Share on other sites More sharing options...
