Front Door Checks
Hey guys, are R50 door checks interchangeable with any other Nissan? My right front door just closes on my legs on a slight hill. My girlfriend has a 2015 Versa and the door checks look pretty much identical
Maybe? The '15 Versa uses 80430-9KK0A, which sure does look the same as the R50 door catch. For some reason, the R50 has a whole bunch of different part numbers (80430-0W000, 80430-0W005, 80430-0W006, 80430-0W007, 80430-0W008, 80430-0W009, 80430-1W300, 80430-1W310, 80430-1W311, 80430-5W900), but it looks like they're all just different revisions of the same part. The first half of the part number is the same as the Versa one, and they sure do look about the same, so maybe the Versa catch is just the latest revision of the same part.
If you can get the Versa one cheaper, or already have one on hand (that your girlfriend won't miss), it might be worth a shot. Measure the length of the rod before you swap in the Versa one in case they made it longer, and open the door slowly the first time until you're sure it won't hit the fender.
  • 1 year later...
So good news! I ended up buying a 2006-2014 Nissan Titan door check and it works! R50 doorchecks cost a whopping $80+. I was about to buy a versa door check but found these on Amazon for $35, less than half than the pathfinder part.
80430-ZC30A
Below is a link to both door checks side by side. The old one is much thicker but I'm assuming since it's for a truck it'll be just as durable
https://imgur.com/a/MNXI5hF
  • 2 months later...
80430-ZC30A
Awesome! Does this part number work on the driver and passenger side front doors? I am looking to buy this for my 97 R50.
