Front Fender
Jimmie
4WD Pathy/pickup outer fenders are the same AFAIK. 2WD pickup fenders aren't flared out as far. I remember finding out the hard way that the mounting points for the rear plastic fender flares changed at some point (probably mid '92), not sure if they did the same for the fronts.
Inners, do you mean the plastic liner or the sheet metal behind it?
The sheet metal. I looked at a 2wd truck this afternoon and you are right about not being flared as much. The trucks around here are easy to find in the Pull Your own Parts and the Pathfinders are getting hard to find. Jim
Edited by Jimmie
