sentra368 Posted December 29, 2022 Share Posted December 29, 2022 What issues could i run into if i were to drive a few hundred meters (or kilometers) in the city, on a paved road, with the front passenger-side CV axle completely removed? I have looked at it closely, and given my rather limited knowledge, i can't see any issues. Please share your thoughts. Link to comment Share on other sites More sharing options...
sentra368 Posted December 29, 2022 Author Share Posted December 29, 2022 I reckon the hole in the knuckle from the back would need to be plugged up to prevent dirt and debris from getting it. Link to comment Share on other sites More sharing options...
XPLORx4 Posted December 29, 2022 Share Posted December 29, 2022 If you don't drive it through water or in dirty environments, it should be OK to drive for a short distance. Link to comment Share on other sites More sharing options...
XPLORx4 Posted December 29, 2022 Share Posted December 29, 2022 BTW, when you remove the CV, be sure to also pull off the thrust washer if it doesn't come off with the CV axle, since you don't want to lose that, and replacement thrust washers are not included with new CV axles. Link to comment Share on other sites More sharing options...
sentra368 Posted December 29, 2022 Author Share Posted December 29, 2022 Thank you for the response, guys. XPLORx4, you referring to the washer that goes into knuckle? Link to comment Share on other sites More sharing options...
XPLORx4 Posted January 4, 2023 Share Posted January 4, 2023 On 12/28/2022 at 11:39 PM, sentra368 said: Thank you for the response, guys. XPLORx4, you referring to the washer that goes into knuckle? Not sure if this reply will be relevant, but I'm referring to the thrust washer that slides onto the end of the CV axle shaft and rides against the inner wheel bearing. It's tapered on one side. The flat side faces out. Link to comment Share on other sites More sharing options...
