Timp Posted November 10, 2022 Share Posted November 10, 2022 Hi All, New to the forum but I am having a problem with my 1999 Pathfinder with the vge33. Recently, after filling up with gas at a very popular gas station, my Pathfinder started acting up. It started by bucking and cutting out while driving which slowly turned into the vehicle running extremely poor (pretty much un drivable). I replaced my entire distributor and set my timing which seemed to fix the problem as the car would idle and run just fine when warm. But a few days later I noticed that the car would die at idle if I had to many electric accessories on such as the radio and headlights. Additionally the car had a very hard time starting when cold, it would crank very fast but didn't seem to want to fire up. If I really play with the throttle and crank the engine for about 30 seconds then I will idle but it will idle very very rough until it warms up to operation temperature where it will run perfectly (aside from dying at idle with the headlights on). I made sure to charge the battery and make sure the distributtor is on correcttly but that didn't seem to help Link to comment Share on other sites More sharing options...
adamzan Posted November 10, 2022 Share Posted November 10, 2022 Did you use an oem distributor or an aftermarket? The aftermarket ones are dodgy at best, I had to warranty mine 3 times before I got a good one. The 2nd one lasted 10km... Link to comment Share on other sites More sharing options...
