CEL disconnect
paathfinderr
Greetings all,
Does anyone know which pin(s) on the ECU power the CEL on a 1992 Pathfinder?  Not which pins trigger the CEL, but which pin(s) supply power to the CEL?  I want to be able to prevent the CEL getting power regardless of any triggering events/faults/codes.
Thanks a bunch
92' has a CEL? I have never seen or noticed one on mine, and I had a bad coolant temp sensor connection for a long time.... Maybe its burned out... I'll have to have a look... The only way I knew I had a problem is when I queried the computer.
