Chunky.Thunder.The.Pathy Posted August 19, 2020 Share Posted August 19, 2020 Hey y’all I have a 2001 LE. It has a leak in the hatch but I’m unable to locate where because the weather seal fits very tightly.. any ideas? Sent from ya mums house Link to comment Share on other sites More sharing options...
Slartibartfast Posted August 20, 2020 Share Posted August 20, 2020 Sit in the back while someone sprays it with the hose, and see where it comes in, or if it comes in faster when they spray a certain spot. If the seal seems fine, check for rust around the hinges. Link to comment Share on other sites More sharing options...
Chunky.Thunder.The.Pathy Posted August 21, 2020 Author Share Posted August 21, 2020 Sit in the back while someone sprays it with the hose, and see where it comes in, or if it comes in faster when they spray a certain spot. If the seal seems fine, check for rust around the hinges.Okay so I found that it is my hatch tail light housing and my rear window hinge. Any advice?Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Mr_Reverse Posted August 22, 2020 Share Posted August 22, 2020 See if the hinge will unbolt (often the nuts will sieze on the stud) and put a thin layer of silicone sealant or mastic between the hinge and the surface where it is leaking and snug the mounting nuts down. Same thing with the light. Thin foam tape should work as well, that is usually what Nissan uses to seal around mounting holes. Link to comment Share on other sites More sharing options...
Slartibartfast Posted August 22, 2020 Share Posted August 22, 2020 Take stuff apart until you find the problem. See if the hinge bolts are loose, see if there's rust around the hinge, see if the third brake light (guessing that's what you're talking about?) seal has a problem. Where's the water come out inside the truck? If you can't find the hole from the outside, pull a trim panel or two and see if you can find it from the inside. Link to comment Share on other sites More sharing options...
