Some Maintenance
Teesetz
Finally had some time to swap out a medium size pile of parts on the thing.
Plugs, Wires, Distributor Cap & Rotor
Fan Clutch, Fan Blade
All new drive belts, Radiator Hoses and clamps.
Just need to flush the system and I’ll be done for this go round.
A couple other things I would do while in there is clean/replace the engine air filter and clean the throttle body plate. If you notice your throttle cable is loose, tighten that up too. I noticed a small boost in performance doing all of that.
Definitely!
I recently did the MAF sensor and air filter. While I was in there I got in the throttle body with throttle bottle cleaner and a toothbrush. Dirtied 2 shop rags worth of carbon build up. Acts like it can finally breath again. lol.
