VG34e Powered R50 Adventure/Build Thread
deltaR50
hello guys. i just wanted to say Hi again. ive been a member here for a while now. go here and there once in a while. ive been building this truck for 4 yrs now and i just never had the time to create a separate build for this truck.
will post pics and vid. stay tune!
truck specs.
 96 Se
3.4 vg34e
euro cams
Kr fab Sfd+aluminum 1 inch spacer front 5” rear 6” rear wj coils
Kyb front struts
5100 bilstein shocks rear
Custom front bumper
Smittybilt 9500 winch
Jeep fogs
Welded front
Navara snorkel d21
Spectre 4 inches inline intake
33x12.50x15 cooper discoverer stt
Warn manual hubs
6k led headlamp bulbs
Additional aux fuse box
Arb air on board compressor
15x10 steelies
Gas can
Cb radio
2x 7 inches Rear led lights
4x 7 inches front spotlights
2x 7 inches front bumper lights
Rock sliders
Ground kit
Trasharoo lol
full catback exhaust new piped 2.5 with Flowmaster 40
Tow hitch
Nissan oem diff plate
Rola vortex roof rack with custom mounts for flush and low profile
just checking local craigslist. no intentions of buying another pathfinder since i already have one. found this as a mechanic special. it doenst start. listed at $600. checked it out the bought it. towed it home. just turns out bad starter. 178k
may 8 2014
53442057_2027646837284982_23262467710443
Edited by deltaR50
******june-july 2014******
since i planned to build this one i decided to do a major tune up. so when i start building it for other uprgades i dont have to worry about its reliability. parts replaced were
timing belt
waterpump
oe thermostat
camshaft seals
oil pump seals
sparkplugs
sparkplug wires
valve cover gasket
valve cover screw and gromets
intake manifold gasket
intake manifold allen bolts (oe were rusted and falling apartt)
heater hoses
knock sensor
painted rust protection for the heater pipes under the intake manifold
cleaned egr
new egr gasket
new power steering. alternator and ac belts
new radiator hoses
new starter
11008477_827210643995280_322743557741811
since im putting a new knock sensor. i pulled the intake plenum and manifold. heater hoses and knock sensor are pretty accesible while the intake mani is out. installed new gaskets and valve cover ones
11196343_827210640661947_351942345852958
did the timing belt and waterpump gave me access to this might as well change it while im at it
11200887_827210670661944_345906860664711
more work
11255869_827216983994646_125981124867431
new valve cover bolts
11041076_827216990661312_419589010022792
old place. where i learned how to wrench
10900199_827217037327974_322511469200451
first off road trip after the full maintenance
carnegie svra in livermore,california
dec 6, 2014
10285833_752833764766302_229502767045196
10749937_752833804766298_324451126092786
1899505_752833794766299_6701746006275635
10856445_752833848099627_682892650427553
10633630_752835288099483_968530436033439
1501196_752835468099465_8058638605573332
10827983_752835891432756_504695510489967
10835247_752836168099395_539564203638255
Edited by deltaR50
  • Like 4
may 2015
few months ago i got lucky that i found someone local that sell his sfd kr fab kit. i think its one of the last production run at the time. i think i paid $600 for everything at the time.
54155001_2027715873944745_73081073062253
5100 bilstein shock
wj coil spring
1 inche rear wj coil spring adapter
steering extension
strut spacers
kr fab pan hard drop bucket
sway bar links
53369447_2027715880611411_45338013993093
Edited by deltaR50
2 hours ago, Mattmill91 said:
That out at carnagie OHV? Looks like it. Your sorta local to me!!! I am in Stockton
yea. its in carnegie. years back. ive been also to modesto area. stay tuned. ive got @!*%load of pictures to post.
may 2015
front
struts removed 14mm  x  3  on the tower. then 2x 21mm nuts for the spindle side
53742586_2028997863816546_53551899158668
placed jack stands on the transmission to hold the engine not falling off when the subframe is being unbolted.
53551196_2028998013816531_68976940740992
dropped the diff.bolted with 8x 17mm on the diff mount while the cv is bolted on the diff with 6x 12mm each side. its must easier to move the subframe without the differential bolted in. also gives you room to remove the engine mount nuts 14mm nuts
53762092_2028992133817119_10080557924708
53208654_2028992070483792_43875624186250
53320042_2028991840483815_66276801016538
53343595_2028991760483823_32784378766515
steering link removed.
53668429_2028992423817090_10090022872987
Edited by deltaR50
may 2015
front lift installation
engine support block is in. subframe dropped ready
53367925_2028992163817116_34175286487757
53043137_2028992177150448_58892732738327
53799343_2028992370483762_33780011413327
strut spacer and nx 1 inch spacer installed
53465134_2028998680483131_27975073889685
Edited by deltaR50
may 2015
rear
removal of shocks and rear coils
53913866_2028991717150494_44334520825985
drill out the hole to fit the bolt for the 1 inch wj coil spring adapter.
53300010_2028991577150508_47973725600334
new vs old coil spring and rear shocks 5100 bilstein
53491958_2028992473817085_36839654932841
coil spring, rear shocks, extended sway bar links, kr fab pan hard drop bucket and 1 inch wj coil spring adapter installed
54228892_2028992433817089_75043246824394
 53811017_2028998573816475_85396870738193
53352609_2028998490483150_53627161717432
Edited by deltaR50
may 2015
after install sfd install
front
54080448_2028998237149842_69704750823636
rear
53305576_2028997810483218_57948563334548
before
53915103_2027716707277995_23657618488520
after
54258262_2029754307074235_77403114715396
2 inches coil spacer lift vs sfd 6 inches lift. both are my rigs.
245/75/16 vs 235/65/15
53419763_2029754287074237_16541069034389
Edited by deltaR50
may 2015
snatch me some 15x10 steel wheels off craigslist.
53603276_2029754257074240_42386655146095
also some meats 33x12.50x15 to go with the wheels so i can get rid of the ugly gaps. looks like rig is skipping leg day from the gym lol
53909707_2029754330407566_49276770789055
53226298_2029765837073082_18558996497144
Edited by deltaR50
first drive after fully installed the sfd and bigger tires/wider wheels.
53496248_2029765730406426_28855974430874
53913878_2029765960406403_38731358503677
53577962_2029766110406388_82183497926699
53641334_2029765757073090_66551031285363
53402690_2029766037073062_30261047727352
53570290_2029765717073094_26096775513075
53725680_2029766060406393_54394199110781
some flexing yea
53752170_2029765683739764_41051978081585
53882736_2029765827073083_83459360911649
54434249_2029765950406404_40326591305387
53639346_2029765643739768_56264003845965
Edited by deltaR50
june 2015
purchased used warn manual hubs here from another member. just dont remember who. it was steal. $100 for 2 pair of manual hubs. 1 pair is this warn and the other one was an oem manual locking hubs from nissan factory.
warn manual hub installation.
53641283_2029782643738068_43481079256260
53478427_2029782627071403_10776946670861
removed auto hubs, 6x nuts and studs, c clip
53716285_2029782537071412_22386247910513
installed warn hub
53793191_2029782473738085_79652622777481
53746393_2029782550404744_43843966798355
Edited by deltaR50
july 2015
hollister hills svra
testing the goodies
gas can added on the factory spare tire carrier inspired by theexbrit also a member here.
11700579_854323254617352_330167033958788
11722090_854323247950686_449005165676869
11728821_854323377950673_577230184734503
11722310_854323404617337_366026594710793
11731707_854323414617336_579178011120929
11218495_854323447950666_846405798123194
11708036_854323464617331_148849623908097
11722478_854323461283998_824849441882308
crazy flex!
11698864_854323471283997_609484909316812
Edited by deltaR50
  • mjotrainbrain changed the title to VG34e Powered R50 Adventure/Build Thread
