PibeGuerra Posted December 20, 2017 Share Posted December 20, 2017 Hello people, I want to put a OEM roof rack on my 04 SE pathfinder. I really like this one because it looks sturdier than the more common 5 crossbar model: https://goo.gl/images/6cGxzx https://goo.gl/images/6jZjzF The problem is that I could not find the instructions to install it,so do not know exactly what hardware do I need. Could you guys help me figure this out?... Thanks in advance. Link to comment Share on other sites More sharing options...
jjonez Posted December 20, 2017 Share Posted December 20, 2017 I thought all SE's from 02-04 had that style rack?? What kind do you have? I would say go to a junkyard and pull the rack you want. That way you end up with all the necessary parts can see exactly what it takes to remove/install. Link to comment Share on other sites More sharing options...
hawairish Posted December 20, 2017 Share Posted December 20, 2017 Yes, just pull the complete rack. Though, the rails on your current rack are the same as the 'lower' rails on the updated style. So, you basically need the upper rails (with Pathfinder letters), crossbars, the front and rear caps, and the plastic trim that goes from rail to the windshield (I think those pieces just slide forward, IIRC). Beyond that, you shouldn't need to make any major changes to your current rack, short of sliding off the 5 crossbars. But you can keep those for additional load support and roof protection...I use a couple on mine for that reason. Link to comment Share on other sites More sharing options...
Carl_99QX4_yeww Posted December 26, 2024 Share Posted December 26, 2024 Hey, just to add to a thread since it's relevant. I have an OEM R50 roof rack for sale. comes with all hardware and roof rails if needed. Pulled from an 2000 or 2001 pathfinder at a junk yard. In good shape, has the "Pathfinder" logo on the side of the rack. asking $200 - Pickup in Crowley Lake, CA. or Can mail but will be a little expensive for shipping. Let me know! Carl (310)469-8971 Link to comment Share on other sites More sharing options...
