sunroof making noise
Guest stormteam
Guest stormteam
Do any of you guys have the same problem i do with your sunroof...at any speed above 40mph, the sunroof makes an annoying whisting noise...any suggestions to making it stop?
I know mine whistles. It's the weather stripping I'm sure. It's riped and torn. Does anyone know where I can get a new seal for it besides the Nissan dealership? Thanks in advance! :beer:
Mine rattled like crazy (but no whistling). I put some sticky backed felt padding under where the latch contacts the plastic when closed. Basically, it holds the parts away from each other and also draws the roof even closer to compensate for the tired seal. So far, so good.
