2000 nissan pathfinder
fearkobe05
what oil weight are you using?
I recommend using a heavier weight than what most oil change shops use. 10w30 at least, made a big difference in both my R50 and Xterra. (vg33 engines)
Seconded on the 10w30, his is a 2000 so its a VG. We do it all the time on older trucks in the shop. The later VQs were a bit more complicated, dual cam and VVT, I always use 5W30 in mine, but an older motor like that can get some use out of heavier oil. Worth a shot
Hello i have a pathfinder making a ticking noise (lifters). Will motor flush help? Oil changes are done regularly. Thanks
Sent from my LGMS631 using Tapatalk
Where is the ticking noise coming from?
Every so often i get a bad and consistent tick coming from my driver side under the vehicle. I’m thinking oil pump. Very curious if you’re experiencing the same?
