Drivers window switch
neilca
I am new to the Pathfinder so this may be a rookie question. The switch to the drivers window has to be pulled up to get the window to go down. Pushing down on the switch raises the window.
The other windows work in the conventional manner. Has the previous owner swapped wires to make the window work in reverse or this this the way the factory intended?
Sounds switched to me.
Sent from my Z836BL using Tapatalk
I see what you did there, LOL. I am wondering if the previous owner replaced the switch with a Chinese unit that is internally switched. The switch uses plugs not individual wires so switching would be difficult.
I accidentally wound the cables onto the driver window actuator backward in my wife's MDX so the window operated opposite, up was down down was up. I like auto up better than auto down so it was sort of a plus.
Edited by onespiritbrain
That makes more sense than wired backwards
