StevozJukebox Posted May 4, 2017 Share Posted May 4, 2017 What other engines can interchange with a 3.3 in 1998 Pathfinder? Link to comment Share on other sites More sharing options...
Remus92 Posted May 5, 2017 Share Posted May 5, 2017 Vg30 is probably the most pain free. But you would drop power and displacement. Link to comment Share on other sites More sharing options...
StevozJukebox Posted May 6, 2017 Author Share Posted May 6, 2017 Didn't they make a turbo model of that one? Link to comment Share on other sites More sharing options...
Remus92 Posted May 6, 2017 Share Posted May 6, 2017 Yes. In the z cars. They also made a supercharger option in the vg33 in some xterras and frontiers Link to comment Share on other sites More sharing options...
StevozJukebox Posted May 6, 2017 Author Share Posted May 6, 2017 Supercharged 3.3 sounds like the easier swap. Do you know what year they made it.? Link to comment Share on other sites More sharing options...
Remus92 Posted May 6, 2017 Share Posted May 6, 2017 I'm not sure. I know some guys on here have them. Basically the early xterras and the matching truck while they still had the 3.3 Link to comment Share on other sites More sharing options...
StevozJukebox Posted May 7, 2017 Author Share Posted May 7, 2017 Are there any models that have a posi traction rear end ? Link to comment Share on other sites More sharing options...
mjotrainbrain Posted May 7, 2017 Share Posted May 7, 2017 Are there any models that have a posi traction rear end ? Only variations in the rear end were open diff or LSD. The only other factor that changed was gear ratio; 4.363 or 4.636. Link to comment Share on other sites More sharing options...
StevozJukebox Posted May 7, 2017 Author Share Posted May 7, 2017 Thanks. Link to comment Share on other sites More sharing options...
deltaR50 Posted May 8, 2017 Share Posted May 8, 2017 injectors and alternator from 97-99 quest can also be used, alternator is an upgrade with an output of 125amp if you planning to run extra electrical acc Link to comment Share on other sites More sharing options...
Snowboarder12345 Posted May 9, 2017 Share Posted May 9, 2017 Supercharged 3.3 sounds like the easier swap. Do you know what year they made it.? 2000-2004 iirc. It came in the Frontiers and Xterras Link to comment Share on other sites More sharing options...
