maddmark1981 Posted April 26, 2017 Share Posted April 26, 2017 So lately I've been having charging issues and suddenly when my power windows quit working a couple days ago it started charging fine but now no power windows... What do I do? Thanks Sent from my LG-H812 using Tapatalk Link to comment Share on other sites More sharing options...
gamellott Posted April 28, 2017 Share Posted April 28, 2017 I wonder.... Do you know if you have a circuit breaker or a fuse for your power windows? If it's a circuit breaker, you may have finally blown it and it won't reset. If it's a fuse, it's probably finally blown. If your power windows are like mine, and there's some kind of timing circuit for the "Power Down all the way", I wonder if that, if the timing circuit is broken, could be the root cause of your issues. The power windows do draw a bit of current, but I doubt that would cause your alternator to not charge. Maybe kill your battery when it's not running, but mine are tied into the run position on the ignition, and are disconnected in any other. I have more questions than answers at this point because there are quite a bit of differences between the model years. 1 Link to comment Share on other sites More sharing options...
vagabond Posted April 29, 2017 Share Posted April 29, 2017 you might want to check the fuse links at the +bat post 1 Link to comment Share on other sites More sharing options...
