Can't remove alternator. Only pivot
maddmark1981
I assume they all mount in a similar fashion? I have a 95. There is one bolt at the top. The adjuster has 2 bolts. The one that adjusts the belt, and one that locks the adjustment bolt in place.
There's 3 bolts. 2 at the top (one up front, one at the rear) then there's the bottom bolt that goes through the adjustment sleeve/ bracket.
Sent from my SCH-I545 using Tapatalk
what he said, at the top 1 at the front 1 at the back then the bolt at the bottom in the adjuster, 14mm socket on the top ones
Edited by vagabond
