shawngs Posted April 20, 2017 Share Posted April 20, 2017 Hi all, I know you are experts and I am but a lowly noob. I have a 2002 Nissan Pathfinder LE and need to replace the tires. What are the biggest size tires that I can put on it without significant rubbing and without having to have it lifted? Link to comment Share on other sites More sharing options...
SellOut Posted April 20, 2017 Share Posted April 20, 2017 31" just a guess but you may need some wheel spacers... I got all 4 spacers for $100 on eBay... 6x5.5 lug pattern and I got mine in 2" Sent from my HTC6535LVW using Tapatalk Link to comment Share on other sites More sharing options...
mjotrainbrain Posted April 20, 2017 Share Posted April 20, 2017 You should be able to fit 31's. Might have slight rubbing depending on the condition of your suspension. You should not need spacers for anything 31" or less, but you might depending on, again, the condition of your suspension and if the tires rub the inner fender lining. Link to comment Share on other sites More sharing options...
fleurys Posted April 20, 2017 Share Posted April 20, 2017 Have a look here : http://www.nissanpathfinders.net/forum/topic/19867-max-tire-size-vs-lift-kit-used-vs-custom-or-oe-wheels/ you will find many users here with their personal experience with this. Cheers,. Link to comment Share on other sites More sharing options...
mickmutante Posted April 20, 2017 Share Posted April 20, 2017 I run 265/70R16 AT tires... No spacers.. Link to comment Share on other sites More sharing options...
NovaPath Posted April 21, 2017 Share Posted April 21, 2017 I ran 245/75/16 without a lift and had very saggy rear springs. Minimal rubbing. Link to comment Share on other sites More sharing options...
shawngs Posted April 25, 2017 Author Share Posted April 25, 2017 Hey everyone, thank you so much for your input! I just realized I didn't mention the size of the tires that are on there now. They are the same as the ones that originally came with the vehicle when it was purchased new from the dealership in 2002. I don't know what all of the numbers mean but they are: R601 245/65R17 111H XL. 1 Link to comment Share on other sites More sharing options...
mjotrainbrain Posted April 25, 2017 Share Posted April 25, 2017 Those are the size that mine came stock with as well. If you throw that number into a site like https://tiresize.com/metric-tire-conversion/ you will find that your stock tire is 29.5x9.6R17, roughly 30x9.50R17. Link to comment Share on other sites More sharing options...
LittleFR Posted April 29, 2017 Share Posted April 29, 2017 (edited) Put your finger between the strut and the back of the tire. My tires on Sig leave me barely enough room to get my hand in with spacers. If you go with spacers good luck finding hubcentric for a Pathy under $350 It's the same as Chevies and Yotas. ( I run Chevy lug centric spacers) Edited April 29, 2017 by LittleFR Link to comment Share on other sites More sharing options...
Megaton Posted April 29, 2017 Share Posted April 29, 2017 I put 31x10.50s on my stock sagging suspension but I mounted them on wheels with a 3.75 backspace. There was minimal rubbing on the plastic splash guards and I could live with that. There is no rubbing after the lift. There is a little tire poking out of the fender well but some Pacer fender flares covered that. Link to comment Share on other sites More sharing options...
joserabagojr Posted May 14, 2017 Share Posted May 14, 2017 I think biggest tires with everything stock - Suspension, bumpers, and lift are: 265/70R15 265/70R16 265/70R17 Depending how big your rims are. Considering everything is stock, it might be a stock 15x7 Alloy rim. You can get bigger, but you need lift spacers and others. Cheers Link to comment Share on other sites More sharing options...
micahfelker Posted May 16, 2017 Share Posted May 16, 2017 Not sure why everyone thinks 31's are the biggest that will clear stock. I fit 32's (265/75r16) with no lift and no rubbing, and I did the same amount of trimming that's common for 31's. I had pretty blown struts too. I can send pictures of how they fit if you want. 1 Link to comment Share on other sites More sharing options...
01Pathmaker Posted May 17, 2017 Share Posted May 17, 2017 Not sure why everyone thinks 31's are the biggest that will clear stock. I fit 32's (265/75r16) with no lift and no rubbing, and I did the same amount of trimming that's common for 31's. I had pretty blown struts too. I can send pictures of how they fit if you want.96-99 (pre-facelift) are typically able to fit larger tires easier than 99.5-04 (facelift) due to different flares and bumpers. Cleared 31's with a little room to spare on my 96, had to do medium-duty springs (~3/4" lift) to clear 265/70/16 (metric 31's) on my 01. Link to comment Share on other sites More sharing options...
micahfelker Posted May 17, 2017 Share Posted May 17, 2017 96-99 (pre-facelift) are typically able to fit larger tires easier than 99.5-04 (facelift) due to different flares and bumpers. Cleared 31's with a little room to spare on my 96, had to do medium-duty springs (~3/4" lift) to clear 265/70/16 (metric 31's) on my 01. Ah okay that makes a lot of sense. I did still have my fender flares on but I had to take off the front mud flaps Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
dwbqx4x4 Posted July 11 Share Posted July 11 On 5/15/2017 at 9:22 PM, micahfelker said: Not sure why everyone thinks 31's are the biggest that will clear stock. I fit 32's (265/75r16) with no lift and no rubbing, and I did the same amount of trimming that's common for 31's. I had pretty blown struts too. I can send pictures of how they fit if you want. Yes, please show some pics. Link to comment Share on other sites More sharing options...
R50JR Posted July 11 Share Posted July 11 6 hours ago, dwbqx4x4 said: Yes, please show some pics. That post is nearly a decade old.. Link to comment Share on other sites More sharing options...
