Z33R50Life Posted April 5, 2017 Share Posted April 5, 2017 Hey guys I'm new to the forums and I have a 2002 LE. I'm looking into fluerys 2 in lift and I'm stuck on the wheel and tire combo I want. I've been looking into some 16x8 0 offset wheels and 255/70/16 all terrain tires. I just wanted some input on what you guys recommend. Thanks. Link to comment Share on other sites More sharing options...
Bunchie Posted April 6, 2017 Share Posted April 6, 2017 If I tell you nothing else, I will tell you this: Your choice of TIRES is of profound importance. Quality tires for our PF's will cost you around a Grand. My story: Spent $170. a corner believing that I got me some decent skins. Truck loaded w/work stuff, I made a left turn around a negative camber corner at speed, in the rain, back tires hit the 2 ft wide painted crosswalk lines and just kept going...in the right direction with the wrong end of the truck. Spun it 180 degrees, hit the curb and did $1800 worth of damage to my rear suspension. My worn out Michelin's had more grip than these new P.O.S's!! Moral of this story: If you can afford $1800 in repairs, you can afford BETTER tires. Pretty rims can wait, especially if you're on a budget. Link to comment Share on other sites More sharing options...
onespiritbrain Posted April 6, 2017 Share Posted April 6, 2017 (edited) Look for a quality used tire shop. I've got one close to me that buys wrecked sets of 3 and when he has a full set he sells them for about $100-$200 each. There was a $1500 set of 37's for $450 with at least 75% tread. You have to look but you can find good used tire shops.. be careful to look at all 4 tires if you find a good set. I found a couple sets that had 3 awesome tires and one typical used tire with 25% tread.. Sent from my iPhone using Tapatalk Edited April 6, 2017 by onespiritbrain Link to comment Share on other sites More sharing options...
rgallant Posted April 6, 2017 Share Posted April 6, 2017 I will chime in buy tires for what you will do and where you live. Pacific Northwest here so wet road performance matters, as well and being pretty rock proof when off road. Lot of guys buy what look cool on some guys truck in a whole different part of the world to find out they do not work where they are. Also bigger and wider is heavier, more wear on truck parts and poorer gas mileage. Read reviews lots and lots of reviews and talk to local guys who do the same sort of off roading, in similar vehicles as you do. Then make your choice. Link to comment Share on other sites More sharing options...
Z33R50Life Posted April 6, 2017 Author Share Posted April 6, 2017 Alright so the advice on tires is pretty solid. Just one last thing, how do I go about choosing the right wheel size? I want to have some good fitment especially with the lift. Is my choice for 16x8 +0 good? Or should I look at different offsets? Link to comment Share on other sites More sharing options...
fleurys Posted April 6, 2017 Share Posted April 6, 2017 Alright so the advice on tires is pretty solid. Just one last thing, how do I go about choosing the right wheel size? I want to have some good fitment especially with the lift. Is my choice for 16x8 +0 good? Or should I look at different offsets? have a look here for some setups : http://www.nissanpathfinders.net/forum/topic/19867-max-tire-size-vs-lift-kit-used-vs-custom-or-oe-wheels/ 1 Link to comment Share on other sites More sharing options...
Z33R50Life Posted April 6, 2017 Author Share Posted April 6, 2017 Awesome I'll check that out and see what I find. I'll order from you soon I'm going to need the skid plate and the spacers. Link to comment Share on other sites More sharing options...
XPLORx4 Posted April 6, 2017 Share Posted April 6, 2017 For what it's worth, I am running 16x8 Ultra 175 Rogue wheels (10mm offset) and 265/75R16 BFG KM2 tires on my 2" lifted Pathfinder, and the tires fit. Link to comment Share on other sites More sharing options...
Z33R50Life Posted April 7, 2017 Author Share Posted April 7, 2017 Wow that's actually the set up I'm looking at. It looks pretty nice, how does it sit with the fenders? Do the tires poke out a lot or is it flush with the fenders? Link to comment Share on other sites More sharing options...
