changing a/c belt
Guest craig
Guest craig
I don't have a shop manual/haynes/chilton or whatever, but I bet if I did, I wouldn't have to ask this:
How do I release the tension for the ac belt? I got the tensioner underneath to take off the first belt, but I cannot for the life of me see where the ac compressor tension is held at..
I searched on here and came up with "by the alternator"....anything more specific?
:Magic:
if I recall correctly, you just remove the top bolt and loosen the bottom. the compressor should pivot on the lower and allow you to replace the belt. To tighten it, throw a big screwdriver between the compressor and the mount bracket. pry and tighten.
Guest craig
thanks a million guys...I was driving myself nuts over this, and I wasn't even looking in the right spot.
:clap:
Guest craig
Damnitttttttt...Now it looks like the idler pulley is seized. It won't spin with the belt....
:furious: :furious:
:furious: :furious:
If I remember right, I think somebody had posted something about replacing the bearings in the idler pulley rather than replacign the whole thing. You might search for it, probably 1 year + ago. And if you find it, post it again. Mine has been making some noise. ;)
Guest craig
Couldn't find it, but I just got a new one at the dealer($50)
When I took the old one off the bearings were all destroyed. Shrapnel everywhere....
