Guest craig Posted March 22, 2005 Share Posted March 22, 2005 I don't have a shop manual/haynes/chilton or whatever, but I bet if I did, I wouldn't have to ask this: How do I release the tension for the ac belt? I got the tensioner underneath to take off the first belt, but I cannot for the life of me see where the ac compressor tension is held at.. I searched on here and came up with "by the alternator"....anything more specific? :Magic: Link to comment Share on other sites More sharing options...
k9sar Posted March 22, 2005 Share Posted March 22, 2005 if I recall correctly, you just remove the top bolt and loosen the bottom. the compressor should pivot on the lower and allow you to replace the belt. To tighten it, throw a big screwdriver between the compressor and the mount bracket. pry and tighten. Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 23, 2005 Share Posted March 23, 2005 The AC belt has it's own tensioner on top of the motor. Big bracket with it's own pulley. Loosen the pulley's center nut, then loosen the bolt on top of the bracket and the pulley will loosen and let the belt tension off. Link to comment Share on other sites More sharing options...
k9sar Posted March 23, 2005 Share Posted March 23, 2005 my mistake. 88 is right, see page 44 (MA-10) of the following: http://www.Nissan-techinfo.com/Nissan/refg...thfinder/MA.pdf Link to comment Share on other sites More sharing options...
Guest craig Posted March 25, 2005 Share Posted March 25, 2005 thanks a million guys...I was driving myself nuts over this, and I wasn't even looking in the right spot. Link to comment Share on other sites More sharing options...
Guest craig Posted March 25, 2005 Share Posted March 25, 2005 Damnitttttttt...Now it looks like the idler pulley is seized. It won't spin with the belt.... :furious: :furious: Link to comment Share on other sites More sharing options...
Mr. Pickles Posted March 26, 2005 Share Posted March 26, 2005 Damnitttttttt...Now it looks like the idler pulley is seized. It won't spin with the belt.... :furious: :furious: If I remember right, I think somebody had posted something about replacing the bearings in the idler pulley rather than replacign the whole thing. You might search for it, probably 1 year + ago. And if you find it, post it again. Mine has been making some noise. Link to comment Share on other sites More sharing options...
Guest craig Posted March 27, 2005 Share Posted March 27, 2005 Couldn't find it, but I just got a new one at the dealer($50) When I took the old one off the bearings were all destroyed. Shrapnel everywhere.... Link to comment Share on other sites More sharing options...
